Results 1 to 8 of 8
Thread: '08 RT factory harness GPS connector
    Kindly curmudgeon W7lej1's Avatar
    Aug 2006
    Spokane Valley, WA
    OK, I KNOW I have seen a thread wiith this information, and I thought it was on this forum.
    But, can I find it - Nooooooo....
    Please - BMW p/n for the pigtail connector that plugs into the factory harness connector for GPS power - under/in front of the gauges.
    I'm gonna be embarrassed, I Know - thanks anyway!
    Marty in Spokane Valley, WA
    '79 R65 - the rolling running project bike
    '08 R12RT - "new scoot"
    Motorsickle Rider brisco's Avatar
    Oct 2010
    De Soto, KS
    P/N is 83300413585
    Maybe this thread http://forums.bmwmoa.org/showthread....lug-on-2008-RT
    Kansas. Eleven curves in three hundred eighteen miles...
    '09 R1200RT '73 R75/5
    N0PGH
    Iron Butt Assoc. #47865
    Aug 2006
    Spokane Valley, WA
    That's the one - thanks!
    jaytro@ptd.net
    Pictures??
    Does anyone have a picture of what and where this connection is located? Thanks!
    Registered User websterize's Avatar
    May 2009
    Frederick, Md.
    The connector, which is covered with a plastic cap, is zip-tied to the throttle-side frame under the tank. See the red wire above.
    Bill Webster
    2013 K 1600 GT
    2009 R 1200 R alumnus
    Sep 2008
    Wilmington, NC
    And that same connector exists on some other models as well, always zip tied in an easy to find up front location. I just used it on a K1200GT, where it was tied right behind the triple tree..
    Cowboyatheart
    Feb 2009
    Pender Harbour, B.C.
    GPS connection
    A friend of mine said his garmin zumo 660LM harness had an end that plugged directly into the BMW plug on his RT. Plug and play.
    Why does everyone say another part is needed?
    Moringa, your body & brain will thank you! PM for discounts Smart Mix at TasteMoringa.com
    XM3 Energy, real energy for the body & brain, no sugar high, XM3.Energy
    May 2009
    Frederick, Md.
    Forgot to note that the connector in my photo above is off a 2011+ R12R. The plug was more buried on my '09. With bright light, you'll find it.
    Bill Webster
    2013 K 1600 GT
