Results 1 to 5 of 5
Thread: another rs handlebar question - 91 k100rs
    Sep 2011
    Western Colorado
    I've got a 91 k100rs and was looking for a set of handlebars that will give me a more upright riding position however I don't want to change my cables or brake line I've heard the k75c or the k75s or the bars off of a naked k work good which one will I need without changing the cables thanks
    Last edited by deilenberger; 04-14-2013 at 12:24 AM. Reason: added year/model to title
    Spring Lake NJ, USA
    2slow (real name?)
    Please read: http://forums.bmwmoa.org/showthread.php?46057
    I'm adding that info to your thread title in the hopes someone with model/year specific info will open the thread and offer some advice. Please add that info yourself in future posts to the tech forums.
    And C bars should work without lengthening anything, and will give you the more upright riding position.
    3 Red Bricks
    Jan 2007
    Pleasanton, Ca.
    K75S bars are slightly lower than the stock 4V K100RS bars.
    LONG MAY YOUR BRICK FLY!
    Lee Fulton Forum Moderator
    3 Marakesh Red K75Ss
    Mine, Hers, Spare
    Apr 2008
    SW Ohio
    I needed a c-type dash-pad and longer brake line with the c-bars. I went back my original s bars with bar backs, nicer esthetically and made a world of difference comfy-wise for me.
    1987 K75S
    Original litter
    Original owner
    2012 Ural Gear Up
    3 Red Bricks
    Jan 2007
    Pleasanton, Ca.
    The CORRECT bar backs are by far the easiest solution.
    You don't have to pull your switch gear and grips off (and risk breaking the wires to your heated grips.
    The dash pad fits correctly on 2V Ks, so you don't have to buy a different pad or cobble a mount for it (evidently, because of the location of th ignition switch on the 4V bikes, the dash pad needs to be trimmed. I don't know what that looks like).
    You don't have to buy different bars.
    Installation time is 15 minutes vs a few hours. AND it's quickly and easily reversable.
    The ones that I recommend are made specifically for early BMW K bikes by A&S Cycles (major BMW dealership in the Sacramento area.
    http://www.ascycles.com/detail.aspx?ID=1349
    Mine, Hers, Spare
