Results 1 to 15 of 16
Thread: 1995 R100RT windshield install
    Registered User jgr451's Avatar
    Jul 2003
    Left Coast Canada
    So I am at the point of trying to push/pull the rubber teats through the holes in the new stock windshield.I got one through,pulled one off and mangled it before I quit.Does anyone have the tried and true method? Tools?Lubricant?
    TIA!
    When I try the search function I get 26 pages of completely unrelated posts and cannot access the post I bookmarked about the 1984 RT(which is probably the same as the 95).
    Sometimes,nothing is a real cool hand.
    Jul 2006
    Bath, Mi
    RT Windshield intallation
    We used WD-40 to WELL lubricate the the "****", and a pair of needle noise pliers to gently pull them thru.
    Registered User PAS's Avatar
    Jun 2011
    N.E. Ohio
    I use the WD 40 and also a small flat screw driver to help PUSH the lip thru while gently pulling the tip.
    DeLand Florida
    I used black RTV after I broke those little suckers off.
    I'd avoid wd40 and other oils as they might attack the rubber. How about armorall protectant. Its very slippery on rubber and plastic.
    As abnormal as it might sound, I would use Dielectric Grease. It is intended for electrical connections and connectors. Connectors are made of all kinds of plastics and rubber compounds and dielectric grease is benign for almost all such compounds. I routinely use dielectric grease on rubber parts because it keeps them from being stuck tight next time I need to take things apart. I have never found degradation of rubber from the use of this grease. If you don't have a big tube like I do you can get it in small packets labelled "Bulb Grease" at most auto parts stores.
    Registered User helmut_head's Avatar
    Feb 2011
    Michitucky
    This IS a bad job
    I hated doing this with my new gasket. But I ended up using a small Philips head to push on them , then a pair of needle nose to lightly pull. I only damaged one of those darn peckers, but it surely ended up being a nuisance.
    Helmut always wears a Helmet.
    Jul 2003
    Left Coast Canada
    Thanks for all the ideas.I have tried WD 40 and a screwdriver,got one through,tore another one all to heck.Will try pliers pushing and grease as suggested by Paul,then if that hangs up badly,soapy water as recommended by Shail...Grrrr!!!!German technology!
    Dawn Dish Soap.Mix three parts water to one part dish soap,apply liberlyand slowly/carefully pull/push your part through. The first time it rains or you wash your bike it will be gone. It's also great for seating tires on rim.
    Smoooooth at 430 gch71's Avatar
    Dec 2011
    Katy, Texas
    House hold Vaseline?... Good enough for kids a&$ good enough for the airhead. Pretty neutral stuff and comes off easy.
    Glenn
    ...driving to work on my airhead
    '73 R75/5, '74 R60/6, '75 R60/6, '80R65
    Aug 2007
    Somers, CT
    lube for windshield gasket install
    I would advise against any petroleum based product unless you know for sure the specific rubber is compatable, some are not. I use Isoproply alcohol on all rubber bits that I need to make slippery. As long as you can keep it wet (IPA dries real quick) I've had no problems with those little nubs. Push with a dull tool on the front and pull at the same time from the back helps. Good luck.
    Jim O'Coin
    Vancouver, B.C. Canada
    Ever since a buddy told me about red rubber grease and it's wonderful properties I seem to be using it on just about every rubber thing I find on a motorcycle. It's actually vegetable based and not only great for rubber bits but even good for your hands.
    See http://www.redrubbergrease.com/
    I think you can buy this stuff at any auto parts store or get a tube on Amazon.
    Jul 2003
    Left Coast Canada
    Thumbs up
    Thanks again for all the ideas!
    May 2006
    Red Rock, TX
    I have a tube of Sil Glide
    Which I think is made for this purpose. I use it in the shop mostly for pulling rubber things through steel things, jamming in weather stripping on cars etc. Claims won't harm rubber. One tube is probably a lifetime investment. Don't recall where I got it. NAPA or something.
    jim
    greyfox
    Red Rock, Tejas
    2004 R1150GSA, 1988 R100GS
    Aug 2007
    Somers, CT
    Isopropyl alcohol on rubber makes it very slippery and it evaporates quickly. I've used this to the windscreen **** many times and have never torn one off. Use it when you remove them too.
    Jim O'Coin
