waxrash
Let me rewind my brain until last winter.....
Yes on the State first. I tested on 450, 550 an 600 and it seemed to be the easiest format to get them in some order. You typically know what state you are in.
The phone numbers were that way from BMW. Don't ask me why. I just didn't take the time to remove the spaces as I could still read them.
You don't need anything else on your GPS if you use POI Loader.
It's a vague memory, but I think you specify the "Group" when loading with POI loader. I know on mine they are in a subfolder.
Assuming I can get the 2016 list from BMW, I'll update probably in Feb/March.
Lynn
Lynn
I downloaded your Zip file for US BMW dealers and installed it on my Zumo 660 yesterday. The March 2015 .GPI 20k file is the one that is now in the Garmin/POI sub-directory.
When I go to:
"Where To?"
Then to "Extras"
Then to "Custom POIs"
All the dealers show up, but the state abbreviation is first in the line, ie:
NY:BMW Motorcycles of New Hyde Park
NY: BMW of Manhattan
CT: Max BMW Motorcycles
NJ: Cross Country BMW, etc., etc.
Is this the correct format I should be seeing, with the abbreviated state first?
Also, when I go into "More" for detailed info about the dealer,
the phone number is spread out with spaces between each number, ie:
( 5 1 6 ) 3 5 2 - 7 4 7 4
Is that correct format too?
Your zip file also contains 2 Excel files, one comma delimited and one worksheet, as well as a 52k .GPX file. None of these transferred with POI loader. I can add them manually through using the USB cable, but do I need those files on the GPS too?
Lastly, when I go to Custom POI's on the 660, it just comes up with the full list of dealers, but doesn't say "US BMW Dealers" first on the screen. If I added another POI list (say all McDonald's restaurants), will they be merged with the BMW dealer list, or would they then be separated into two sub-groups? If not, how can I make the GPS show the POI title?
I also PM's you this note in case you see that first.
Thanks a million!
Larry
