Results 1 to 13 of 13
Thread: R60/5 Throttle Cables
    Jun 2007
    Minneapolis, MN
    Moving along, the throttle & cam gears were shot so ordered new parts & tonight installed new Magura throttle grip & cam.
    It seems to me the throttle cables are too long - I snapped a picture - the other issue is the throttle isn't snappy like my R65LS - on that project she got new throttle cables and a grip & cam set.
    Next question: this bike has two individual throttle cables - there is a top and bottom position where the cables attach to the cam - is there a right and a left position? It may be in the Clymer & Haynes service manuals but I didn't catch it.
    Here are the pics - I'm really thinking these throttle cables are too long
    Ken Tuvman
    Excelsior, MN
    K75s, R65LS, R60/5
    Jun 2007
    Minneapolis, MN
    Here's where the two throttle cable attach to the throttle cam - wondering if there is a right and a left position?
    Ken Tuvman
    Excelsior, MN
    K75s, R65LS, R60/5
    Jun 2007
    Minneapolis, MN
    Here's a pic of my handlebars - I looked at the various styles on Hucky's site - can't really tell what style they are.
    Ken Tuvman
    Excelsior, MN
    K75s, R65LS, R60/5
    No left or right position on the cable hookup inside the throttle housing. I just went through this on my R69S. The cam/chain mechanism just pulls both cables evenly.
    As for cable length, I know the cables can be too short. I that case, they make a tight turn going into the top of the carb...not good. Plus the cables can get pulled when turning the handlebars. But being too long is not necessarily a bad thing, unless they're way too long and flop all over the place.
    Jun 2007
    Minneapolis, MN
    Makes sense, Kurt - can /5 be lubed - they look okay but are not snapping back when I release throttle - throttle stop screw is removed
    I may invest in a new set of cables - these may be oem - from appearance they look good - will tinker a bit more
    Ken Tuvman
    Excelsior, MN
    K75s, R65LS, R60/5
    Check for binding with the grip and throttle tube. If you have the grip too close to the throttle housing, that will hang it up.
    Do the cables move freely out of the bike? The cables shouldn't need lube, especially not new. Lubing might be something you would do as a last resort on old cables. IIRC, OEM cables have a special lining while doesn't need to be lubed.
    Jun 2007
    Minneapolis, MN
    I'll check cables when I remove carbs - just ordered an Ultrasonic cleaner from Harbor Freight - the carbs need a good cleaning! The cables are not new. I sent an email to Hans @ Hucky's with a pic of my handlebar & s/n of bike to confirm correct throttle cable length. I'll get to the bottom of this!
    Ken Tuvman
    Excelsior, MN
    K75s, R65LS, R60/5
    Jun 2007
    Minneapolis, MN
    Hans confirms throttle cables too long - going to invest in a new pair - as Lew said awhile back, he'd bet a dollar to donuts they're probably shot!
    Ken Tuvman
    Excelsior, MN
    K75s, R65LS, R60/5
    Eastern KY
    As to cables on a /5 I have a question of choices. My situation- I just got a pkg from Flanders in the mail today of components to make up the 3 new cables for my Bultaco project. They are the nylon lined style of outer cable/conduit.I'll have these in place for much less than any other choice available to me. So, what are the better cable choices for my /5 project based on both cost and function, assuming I want them to look new as well?
    Jun 2007
    Minneapolis, MN
    I ordered mine from Hans @ Hucky BMW in Vero Beach, FL - sent a picture of my handlebars & he confirmed they're the Euro version - they were very reasonable like @ $15 a cable (guessing). Fast delivery and they work perfect - look nice too.
    Ken Tuvman
    Excelsior, MN
    K75s, R65LS, R60/5
    Eastern KY
    The components alone cost ~$30 for the 3 cables I'm putting together now & they are bit lighter wire than an airhead, so thats a good value.
    Macrunch MCrenshaw's Avatar
    Bedford, TX
    Ken, as to the issues about the throttle "snapping back", if memory serves on your /5 you do have CV carbs but they may not have springs on the slide. Your R65 does I believe. Just pull the top off of one carb on each bike to check.
    Jun 2007
    Minneapolis, MN
    Snappy Throttle
    Quote Originally Posted by MCrenshaw View Post
    Hi Mike
    Throttle snaps back now that I have the right length cables, new throttle & cam assembly - the frosting was loosening the throttle perch and making some adjustments - throttle action is now beautiful.
    Carbs are Bing Type 53
    Ken Tuvman
    Excelsior, MN
    K75s, R65LS, R60/5
