Results 1 to 1 of 1
Thread: cool hidden eq setting on new iphones and iPods with iOS6!
    just found great new eq adjustment for ipods/iphones for music while riding
    Late Night Equalizer:
    Apple has added a new equalizer settings in iOS 6, which compresses the dynamic range of the audio output, reducing the volume of loud passages. You can use this setting while going to bed or when you‘«÷re listening to music on an airplane or in some other noisy environment (like for example, on a bike!!!).
    You can enable the Late Night Equalizer setting by following these steps:
    Go to EQ under music in settings. Find "Late Night" and select it.
    This will compress the music so that you won't have to live with:
    --setting volume to hear comfortably but not hearing the soft passages, (then you end up turning up music and killing your ears...).
    2012 R1200RT, 2004 Vespa GTi, 2001 Kawasaki 220R, 1981 Vespa P200E, 2004 BMW 325i
