Results 1 to 15 of 18
Thread: Bosch spark plug question
    DennyPink
    Mar 2009
    Fort Collins, CO.
    Fellow Airheads;
    I made a purchase ass-backwards. I bought a 4 pack box of Bosch WR7DC spark plugs, then read Snow Bums article and he recommended against using any plug with the "R" letter, meaning it is a resistor or resistance plug, not to be used in airheads. My 1992 RT owners manual recommends Bosch W7DC. Do I now own 4 paperweights? Thoughts please. Thank you!
    Denny Pink
    unopened, you should be able to return them; especially if you seek an exchange for the correct item.
    Houston, TX or Portland, OR
    I'm not sure you will be able to find Bosch W7DC plugs easily... you may want to opt for NGK plugs which are equivalent and readily available.
    Jim
    '90 and '93 Mazda Miatas (Jelly Bean and Red Hot), '02 325ci (Blue Streak)
    Be sure and find the right matching when going to NGK. The temperature rating scheme on the plugs are different. IIRC, Bosch W5 is a colder plug than a W6...reversed on the NGK.
    Yes- good point! The numbers do go in opposite directions for the two brands. I think the Bosch W7DC equivalent NGK part number is BP6ES. That said, I see Rick (Motorrad Elektrik) is recommending NGK BP7ES for all 1000cc twins '81 and onward:http://www.motoelekt.com/ignition.htm (scroll to the bottom).
    I recall Snowbum has a comparison table: http://bmwmotorcycletech.info/sparkplugs.htm
    Here are couple of other pages from the net that might be helpful...
    This page has a nice chart about halfway down the page showing the compatible the NGK and Bosch plugs from hotter to colder:
    http://matchlessclueless.com/mechani...n/spark-plugs/
    This has a complete compatibility chart:
    http://www.clubplug.net/bosch_ngk.html
    Jim
    Quote Originally Posted by jad01 View Post
    It's as easy as a trip to your BMW dealer.
    Mmm... that maybe true for some dealers. My local dealer only carries the NGKs these days. So... your results may vary!
    I do see on the parts fiche that MAX BMW carries them (W7DC) for $6.88 each.
    Jim
    "Carries" is a vague word here.
    Your BMW dealer has a BMW part number for the Bosch plug.
    He doesn't for any NGKs for Airheads.
    Bluenoser
    Lethbridge Alberta
    Run the plugs that you've bought. I would be surprised if you had any issues contrary to popular opinion. The 5k resistance isn't going to hurt anything. I can't think of any electronic ignition that is going to be bothered by that small of a resistance level. You'll have more issues with bad wires or bad plug caps than you will have with that small of a resistance. In fact if you are going to go to NGK go to Iridiums. I've used them on point ignition equipped bikes and they work better than the stock plugs.
    If not then take them back and try again.
    2013 DL650
    American BMW owners often seem to STRONGLY resist the following truism:
    If you own a German vehicle, they DO NOT have parts for your bike at PepBoys, NAPA, etc. Pretty unlikely at "motorcycle superstore," too.
    Now that you own a European vehicle it's time to leave old American ways behind and catch up to your bike. Yes, it's a culture shift.
    When your bike was designed, there was ZERO consideration given to whether it could be maintained by typical American DIY methods. You'll have trouble forcing this approach on your bike. Go to Germany some time and see if you can find a PepBoys.
    Various importers, including your dealer, are your best bet. Heck, I've ordered tires for my G/S from the UK.
    Registered User helmut_head's Avatar
    Feb 2011
    Michitucky
    NGK Iridiums work nice. Funny thing happened to me. I ordered 2 from Amazon, they sent me two boxes full (16 pieces) for about $12.00.
    I returned the spares......................
    HH
    Helmut always wears a Helmet.
    Feb 2011
    Michitucky
    Sad truth, you can buy oil, but even most metric BMW bolts are difficult for the American auto parts store.
    May 2006
    Thats what my dealer sent.
    Jul 2009
    Quote Originally Posted by DennyPink View Post
    Fellow Airheads;
    Denny Pink
    Try parts stores that sell VW Bug parts. JBugs lists the W7DC as being available. $3.00 each.
    Apr 2012
    Gilbert, AZ
    Look on eBay. I got a bunch of NOS W6D's there a while back for about $1.50 each.
    2004 R1150RT
    BMW MOA 181289
