Results 1 to 15 of 21
Thread: 1980 R100 front brake free play
Hybrid View
    I am completing a frame on restoration of a 1980 R100. I am having trouble with the front brake free play. The front wheel turn with just a little drag, as does my 1984 R100. The master cylinder cable has what I believe is the correct free play, yet I have almost no free play at the lever. The only way I can accomplish free play at the lever is to loosen the cable to the mc too much, as in the cylinder at the end of the cable isn't even touching the master cylinder lever that pushes the plunger. The mc seems to be working right as fluids exiting and returning are evident when I take off the cap and look into the reservoir. Anybody have any ideas?
    Fenwick, Ontario Canada
    Going back from memory, there is a special feeler guage from BMW to set the proper gap so I don't think it's meant to touch.
    Hope this helps!
    Knights of the Roundel #333
    I'm not sure if the '80 model had the under-tank M/C. If so, then as Darryl suggests, there's an adjustment at the back of the M/C to ensure that the internal piston is in the right spot. Shown here on a /6 owner's manual:
    http://www.pbase.com/dwerbil/image/74356089
    Pismo Beach, CA
    Ref., 1.20mm = 0.047"
    Being a /5 kinda guy I don't have a master cylinder. It's hard to tell from that old B&W manual photo; mechanically what's going on here, does the "fork" fit around the machined groove (holding it in place), and the "slack" is taken up/let out with the ferrule?
    Lew Morris
    1973 R75/5 - original owner
    1963 Dnepr
    My Haynes says:
    "Slacken the cable adjuster locknet and insert the forked feeler gage into the groove in the master cylinder piston. [Note: the feeler gage is 1.2mm thick.] Adjustment is correct when the feeler gage is just freee to move against the master cylinder body."
    So, if there's too much tension on the cable, it pushes the small cylindrical shaft which pushes the piston farther into the m/c body and the groove moves with it, eventually disappearing inside the m/c body. Too little tension, and the groove comes too far out. So, the free play/tension has to be just right so that the groove is near the m/c body but just near enough to fit the feeler gage into the groove.
    Pismo Beach, CA
    I can see how that would be p-r-e-t-t-y hard to do without the special "feeler gauge".
    Thx Kurt.
    Lew Morris
    1963 Dnepr
