Results 1 to 15 of 15
Thread: replacement shocks for r90/6
    hi all,
    has anybody used a set of the replica replacement shocks from bob's BMW?
    http://store.bobsbmw.com/product/bob...974-76-6--r90s
    i need to replace my shocks, and i want to keep the stock appearance of my bike. so i'm looking to see if anybody here has tried them.
    thanks,
    -eric
    BMWMOA #182796
    '76 R90/6
    WI Airhead r90r100r's Avatar
    Aug 2006
    Title Town, Green Bay, WI
    At 120k miles, I replaced the originals with Ikons. I liked the Ikons/Koni reputation and are also rebuildable.
    Mike Horne
    76 R90/6
    93 R100R Legend
    Administrator 20774's Avatar
    FYI...the "son of" shocks for Koni is the Ikon.
    but i like the aluminum shroud, and as far as i can see, the ikons don't have that stock appearance:
    http://www.ikonsuspensionusa.com/servlet/Detail?no=1
    BMWMOA #182796
    '76 R90/6
    Macrunch MCrenshaw's Avatar
    Mar 2008
    Bedford, TX
    Take a look at Hagon shocks. If you like what you see then call Dave Quinn a call and he'll help you size them. Hagon does have shocks with chrome shrouds although not Girling look alikes. I put a pair on the R65 and it was an amazing difference in the ride.
    Aug 2011
    Arlington, TX
    just replaced mine
    I just replaced my original shocks when I had to replace the final drive. I had it all apart so I figures this is a good time.
    I installed shocks from Progressive Suspension. I tried to disassemble the originals to reuse the aluminum shroud but the originals were stubborn. So with help, I torched the originals apart to salvage the shrouds. They were pretty easy to install onto the new shocks instead of the cheap plastic supplied with the aluminum shrouds. They don't look exactly original but here is a pic.
    They ride very nicely
    brian
    1976 R90/6
    Member# 174498
    Registered User dmftoy1's Avatar
    Mar 2012
    Lexington, IL
    Quote Originally Posted by ezwicky View Post
    You can get your original shrouds off and buff them up if you're patient. FWIW
    Bluenoser
    Mar 2010
    Lethbridge Alberta
    Motobins in the UK sells stainless steel shrouds for these shocks.
    Somebody said be patient to take the olds ones off. Please explain, I would like to know how to do this as my springs need repainting. Shocks are still go, no leaks etc., just the springs are rough looking.
    1999 R1100s
    Mar 2012
    Lexington, IL
    The trick is compressing the coils enough to get a wrench on the flats on the rod that's under the top rod. I used hose clamps looped through the coils but its a major pita. I'm sure there's got to be a better way.
    Saltwater
    Feb 2013
    Washington State
    Yes I have them... but not the same bike as you
    I have Bob's shocks on my 1978 R80/7, but the non upper shroud version. They are the same, but no aluminum shroud. Frankly, I can't tell the riding difference between OEM and Bob's. The originals that came with my non running, $800 mini storage queen had rust and flaking chrome, so that was the main reason for replacement. No oil leaking. Bob's claims they can be rebuilt, but I see no way to disassemble them. They look just like the OEM's, all welded, and no way to access internals. I Googled the manufacture shown on the warrantee, but they don't come up. Just reporting my observations so far -- new to airhead ownership, and do 100% of my wrenching, but not an experienced expert in any way. They perform well, and look fine.
    Sep 2004
    Arlington, TX
    Shocks
    Wait a min. here! The question was about the repro shocks from Bob's. So let's try to answer the question that was asked. My experience is that I put a set on a restoration that I did two years ago, at the customer's request. To the best of my knowledge, they're still working like new and are the equivalent of the original Boge (sp) shocks that came on the bike.
    So with that in mind, I bought a pair for the restoration that I'm doing for myself. If you look at the reproduction shocks, you'll notice that the top mount/eyebolt is different from the original. So, I think, I'll just replace it with an original top piece, to make it look original. Well, it turns out that the thread pitch is different, so I had to drill out the original top piece and use a Heli-Coil with the right thread pitch to make it work. Just so you know.
    Boxerbruce
    P Monk
    May 2005
    Port Neches, Texas
    I bought Bob's shocks
    They don't do anything for me. If you really want them I would trade for some good Ikons or Hagons.
    P. Monk
    74 R90/6 (also know by bride as the Black Hole). 09 R1200 GS. My wife, 1953 model who has survived aplastic anemia and a bone marrow transplant.
    Northern Front Range, CO
    Quote Originally Posted by cycleman2 View Post
    just because they are not leaking does not mean that they are "still go(od)". If original, they are over 40 years old. Shocks are a wear item, as well as a safety component.
    Ride Safe, Ride Lots
    Pismo Beach, CA
    There absolutely is a better way...
    Here's 'Bum's article on the subject. > http://bmwmotorcycletech.info/tools.htm
    Another old thread on the subject > http://forums.bmwmoa.org/showthread....k%20compressor
    But there are all kinds of ways to accomplish the task... once you know what has to be done. Once you get the aluminum cover (along with the coil spring) compressed far enough to get a thin 10mm wrench on the flats (ground onto the shock strut) you simply unthread the cast aluminum mounting "eyelet" on the end of the strut.
    Lew Morris
    1973 R75/5 - original owner
    1963 Dnepr
    went with hagons from dave quinn
    Quote Originally Posted by mcrenshaw View Post
    i just did exactly that. ordered the classic I with stainless body and shroud, and black spring.
    looks almost identical to old stock one that i had on my 75/6 back in the '80s. dave seems like a good guy. i like dealing with small businesses.
    http://www.davequinnmotorcycles.com/...IN_SHOCKS.html
    scroll down to the last picture. i ordered number 3. by the way, according to the hagon UK site, that hagon logo peels off
    thanks everybody for contributing to this thread.
    -eric
    BMWMOA #182796
    '76 R90/6
