Results 1 to 6 of 6
Thread: Petcocks
    Apr 2012
    Pulaski VA
    Petcocks
    My 73 /5 seems to have Germa petcocks. They look like the Karcoma's but have the screw in the handle. Are these rebuildable with Karcoma parts or should I change them? I understand the period correct ones would be Everbest.
    Aug 2010
    Calgary, AB. Canada
    Quote Originally Posted by kjmcd13 View Post
    Would by some chance would you have a picture?
    Rick MacPherson
    1968 BSA Starfire, 1976 BMW R75/6, 1992 R100RT, 2009 R1200RT
    Sep 2004
    Arlington, TX
    Petcocks
    The answer is a qulified yes. If you go to any one of the on line parts suppliers, you'll see different pictures for each petcock. The parts are a bit different for each, so you need to order the right parts depending on which you have.
    Boxerbruce
    Apr 2012
    Pulaski VA
    Pismo Beach, CA
    Another shot from Ausherman's website
    Internals (item #: 12, 8, 7,6,5,4,3,2) are available from MAXBMW, but if the "hardware" is worn out it's NLA.
    As long as you just LOOK at your motorcycle Everbest petcocks will be fine. The ones on my '73 R75/5 were garbage and leaked (wept would be a better word) from the beginning. Karcoma straight-throughs are the ticket.
    Lew Morris
    1973 R75/5 - original owner
    1963 Dnepr
    Apr 2012
    Pulaski VA
    Karcoma's it is, then!
