Page 1 of 3 1 2 3 LastLast
Results 1 to 15 of 32
Thread: Top Case Suggestions?? '08 R1200RT
    Registered User bobframe's Avatar
    Jan 2013
    Northeast GA
    I'd like to have a top case for my '08 R1200RT but, like many, I won't spend what it takes to get the OEM case.
    I had a Givi Monokey on my Honda ST and liked it well enough, though I always thought it looked like a add-on. I also tired of using the key to open it each time. A friend tells me his Givi Trekker can be opened without the key...sounds good to me....let me decide when to lock it.
    So....suggestions on a handsome, highly functional and reasonably priced top case? If you are recommending a non-OEM case...can you comment on the mounting arrangement, that is, how much of a mess are you left with when you go "sans-case"?
    Many thanks,
    Bob
    Last edited by deilenberger; 03-24-2013 at 05:41 AM. Reason: added year/model to title
    We don't take a trip...the trip takes us.
    2016 BMW R1200GSA
    2012 Honda XR650L
    BinkleyLane binkleylane's Avatar
    Jul 2012
    Springboro, OH
    I got the Givi 46 Mono Key off the forum flea market with the light kit and universal mounting plate and brackets. Install was easy and straight forward, no residue or modifications. Mounting bracket lays on top of existing luggage rack and can stay on or be removed easy enough; four butterfly brackets. Light kit wires directly to the bike wiring and is hard wired via a waterproof plug on the case.
    Fit and finish are good and functionality cannot be beat especially at 250 bucks.
    The key system is ok and I can leave it unlocked and not use the key every time.
    I have not yet taken a trip with it but I know it will simplify long trips.
    I did add the top rack so I can carry some light stuff outside the box.
    Hope this helps.
    B-est M-otorcycle (in the) W-orld
    Have Bike - Will Ride
    Sheboygan, WI
    Smile
    Mounted a GIVI E55 on my R1200RT - looks great (mistaken for OEM).
    It is 55 litres vs. BMW's 49L case.
    Also, it doesn't bounce around like a pogo stick like the BMW one did.
    Lends itself well to the Givi luggage rack too.
    All around, the best choice out there IMHO.
    Dec 2007
    Auburn, AL
    Charlie
    Auburn, Alabama
    Current - 2012 R1200RT, 2012 CBR250R, 2014 DL650 Adventure, 2013 PCX150
    I put a Givi E55 on my '12 RT this winter and LOVE it. The custom bracket went on with ease and the box couldn't be easier to open or remove from the bike. I did not like having to use a key each time to open so I had a duplicate key made and cut off all but a small piece that sticks out of the lock cylinder far enough to turn. I leave it in all the time but could take it out if locking was important.
    It holds so much that on short trips I some times leave my side cases at home. With the silver trim on the case I think it looks good with the bike. You can opt for colored tops or have one custom painted if it is that important. The stock top on mine is textured and has been scratch resistant so far.
    na1g
    May 2011
    Greater Bahstin, Massachusetts
    I have the Givi V46NT (matte black w/clear lens - looks great on my Thunder Gray 2011RT). With the case removed the rack looks good. Except for the two latching hooks that stick up 1/2", the surface is flat. I thought the mounting instructions were less than good and the actual installation a bit fiddly but not hard. Removing the mounting plate leaves the bike unharmed.
    pete
    Albuquerque, NM
    I bought a good-as-new used BMW 49l case for ~$500. Then shipping then rekeying charge.
    I'd keep my eyes open and search the classifieds, as BMW styling looks best by far on BMWs.
    Kent Christensen
    21482
    Droptine1968
    Feb 2013
    Toledo, Ohio area
    Quote Originally Posted by na1g View Post
    pete
    I have the same one, and I wish the mounting brackets that goes underneath the stock rack was one piece instead of four. It's a bit of a pain. I remove everything every time I wash the bike because of that foam cushion probably wouldn't dry well and start to either smell or decay. Somewhere recently, I saw some website that has an aluminum plate made for GIVI cases. It goes over the stock rack and does not appear to need those brackets to go underneath the rack. It doesn't show that they're making it for the R1200RT yet. But they do make some for a couple K bikes.
    2005 R1200RT
    na1g
    May 2011
    droptine, you're absolutely right. First figuring out which piece goes where, then holding it in position while threading the bolt through the mount and into the part underneath the rack... I needed more hands and some funny fingers. I found that taping the small underneath piece in place with some painter's tape helped get things started.
    Never thought about removing the mount for washing, but you are probably right. Water + aluminum = corrosion.
    pete
    AZ
    +1 but got mine for $400 and keyed it myself. The OEM case is much better than anything else out there. (as judged by both construction quality and passenger comfort)
    MOA #107139
    RA #28511
    YB #2005
    Sep 2011
    Western Massachusetts
    I'm really happy with my Shad SH 48. I like the shape better than the BMW box and unlike the Givi it does not require a key to open unless you lock it. It also has a nice back pad for the pillion. Quality is certainly on par with the Givi and it doesn't seem to bounce a round as much as the BMW box on my buddies RT.
    Registered User Brian-NC's Avatar
    Feb 2006
    Charlotte, NC
    Like you, I was shocked at how much the OEM trunk was so I made a deal on a Givi E52 Maxia and mounting plate, installed before I rode it home. It was a total of $350.00 and has a capacity of 52 liters.
    Brian-NC
    (Matthews)
    Current bike
    2010 RT Ostra Grey
    Feb 2006
    Charlotte, NC
    And another view. You can see where I installed a black reflective tape kit designed for the Givi. You can also add a brake light kit to it as well as the E55 Maxia where as there is no such provision for the OEM. It's rock solid at any speed.
    Brian-NC
    (Matthews)
    Current bike
    2010 RT Ostra Grey
    Sheboygan, WI
    Smile
    Quote Originally Posted by Brian-NC View Post
    Way nicer looking (not to mention bigger and more solid) than the 49L OEM 'dumpster.'
    Jan 2013
    Northeast GA
    Brian, that looks good. Any chance you could take a pic of the mount taken without the case? I'd like to get a sense for how obtrusive the Givi mount is. Thanks very much,
    Bob
    2016 BMW R1200GSA
    2012 Honda XR650L
