Results 1 to 15 of 72
Thread: DIY vs Warranty
Hybrid View
    Registered User sickticket's Avatar
    Oct 2012
    Dublin, Pa
    DIY vs Warranty
    Past Yamaha and Honda guy. Just ordered my first BMW - 2013 R1200RT. My butt is itching.
    Anyway, I'm a machinest, CNC programer/setup/operator so I know my way around machines and tools. I've checked out this site for maintenance instructions and it all seems rather straight forward. I am concerned about maintaining the warranty and still do most of the work myself.
    What do I need to do to prove all the scheduled work is done properly?
    Thank you in advance.
    Registered User kenlavine's Avatar
    Oct 2009
    Western Massachusetts
    DIY vs Warranty
    I was just looking at the same bike and asked the service department manager the same thing thing. He said as long as you do it right there is no issue with warranty.
    Wilmington, NC
    I can verify that from personal experience. I do all my own and have a couple times needed a warranty replacment (an fpc, for example). Never had a problem with it- even at dealers other my local one.
    I use the factory service forms for all regular service that you can find on the web and make notes on them for anything done in between.
    Remember you will need a GS-911 to reset the service indicators and check codes or will need to get a dealer to do that for you.
    Also, FWIW, should you ever buy a used one there is no problem getting recall updates done at any dealer either. I recently added an 06 K-GT to the fleet and had the local dealer do the suspension link recall.
    RAINEY 187132's Avatar
    Sep 2012
    Grand Rapids, MI
    Like others have said as long as you can prove that you have maintained the bike and performed the required service items your okay. You will need to prove if asked that you have purchased lubricants that meet spec and of proper viscosities. They will also look for items such as filters, seals and anything else that would be needed for proper completion of the service.
    Do keep in mind that if the dealer performs the service for you, you will have a better chance of getting good will warranty assistance on major components if the dealer has been involved all along. I've seen this to be true in motorcycle and car dealerships. The dealer is more likely to push the factory rep for assistance on your behalf if they have had an opportunity to see you after the initial sale.
    Jason
    Grand rapids, MI
    2012 BMW R1200RT
    Oct 2012
    Dublin, Pa
    Well, thanks for the responses. Having not dealt with BMW dealer for service, are the charges high for labor for valve clearance checks or other types of maintenance? Obviously the oil changes and minor stuff so easy to do I would be reluctant to ask for their help.
    Besides oil changes and valve clearance checks, what other types of scheduled maintenance is required?
    Peter
    Diamondhead, MS
    Federal Law prevents dealers from denying warranty service regardless of where work was done. Lack of proof does not mean lack of warranty. A lot depends on whether or not the dealer is ethical.
    Quote Originally Posted by sickticket View Post
    Check valves, oil changes, sparkplug changes, air filter changes, alternator belt changes, check battery, brake pads and rotors, brake bleeds, cables, clutch fluid level (the level RISES as the clutch wears), center and side stand pivot lube, lights, tires, and engine start suppression.
    The list will vary with specific bikes. I created a checklist for use on my bike (an '05 GS). http://www.snafu.org/pics/r1200gs/service.pdf I keep the checked off list in a binder along with receipts for parts. When I get a new bike I'll create a new checklist for it. Data for the checklist came mostly from the RepROM [repair DVD].
    Canada and the Alps
    Quote Originally Posted by scalese01@verizon.net View Post
    Perform all work as per the maintenance schedule.
    Keep a very detailed log of the work performed along with the date and mileage.
    Keep all receipts for parts purchased from a BMW dealer as well as lubes purchased.
