Page 1 of 3 1 2 3 LastLast
Results 1 to 15 of 45
Thread: Oilhead surging
    Badger
    Jun 2006
    Twin Falls, ID
    Oilhead surging
    I've owned a 2004 R1150RT twin spark (which I never should have sold!) that never had a surging problem. Also owned an R1100GS that surged like a chronic asthmatic; that was pretty much eliminated with the installation of a "Power Commander." I'm now in the market for another R1150RT or an R1100RT. Do the single spark R1150RT or the R1100RT models have a surge problem? Thanks.
    Retired from riding rad's Avatar
    Santa Cruz
    All the single spark Oil heads can surge to some extent. How much of a problem it is depends on the bike and how sensitive you are to it.
    In specific response to your question, I had a single spark 1150rt and it surged. I changed the cat code plug (dont remember to which one, and changed plugs to non-stock and she was fine after that.
    Oct 2011
    Florida & Massachusetts
    Quote Originally Posted by 35751 View Post
    Many riders report that the single-spark R1100 and R1150 have varying degrees of "surging", which is a broad topic. The dual spark 2004 R1150RT to a much lesser extent. There are a class of Lambda-shifters like the Innovate LC-1 which can remove the surging. It may also be that some plug 'n play devices will turn up to do the same job as the LC-1 but much more simply.
    MOA #24991 Pauls1150's Avatar
    Apr 2008
    south of Los Angeles
    It was worse with the 1100s but they both have the issue; how badly depends on how well the assembly line (and then followed up by a competent tuner) set up the valves, the TPS (including the baseline Zero), and sync'd the throttle bodies. The cure is a combination (total summation) of tuning corrections. There are a jillion and a half articles and posts on various sites about this already; search this site with the window at the top right ("throttle body", "TPS"), or if the history got nuked with the last upgrade, go over to the Internet BMW Riders and look through the Oilhead Tech articles. http://www.ibmwr.org/
    Jan 2012
    New Rochelle, New York
    Oilhead surging
    I have a '96 r1100rt. I am the second owner. No surging problems and frankly didn't know there were any until every once and awhile I see something posted on this web-board.
    I have every single dealer and previous owner maint. logged from day one.
    Straight stock, nothing has been altered or modified because of surging.
    It has 72,000 miles.
    Does anyone know when this started or was it just an anomaly with certain years (or half years) or models? Something must have changed.
    mike wex
    '96 r1100rt
    Northern Front Range, CO
    Mike- earliest year oilheads (which your bike might well be) had a CCP (cat code plug) which created a slightly richer mixture, which effectively eliminated the surging. That was changed by '97 or so. Surging is generally understood to be a "hunting" by the EFI to achieve the correct A/F ratio. What functionally happens (others, probably Roger04RT, will give deeper analysis) is that the EFI adds more fuel, sees that it's too much, then gives too little, then has to add more, ad infinitum. Happens most at consistent throttle settings. Whe riding hard it does not surge as you are steadily adjusting/adding fuel yourself, or when rolling off as you are asking it to deliver minimum fuel anyway.
    Ride Safe, Ride Lots
    Jun 2005
    Green Bay, WI
    True,....and not quite. My 94 RS (built in Oct 93) had no CAT code plug at all. The very early Oilheads ran a bit more rich before the CAT code plug system was added. I never had any surging problems at all.
    That said, I have ridden other Oilheads and never noticed a surging problem. But they do respond well to a Power Commander or Booster Plug or Techlusion, to richen up the mixture slightly.
    i run a booster plug on my 00 r1150gs took out 95% of the surging. but also lost a couple miles per gallon.
    Santa Cruz
    Almost two decades of surge threads on the internet, starting on the "Big List"...What a crack up
    Ive owned 5 Oil heads; my surge dance card played out as follows;
    96 1100RS, surged very bad at speeds between 30-50mph making around town stuff very unpleasant
    99 1100S, no surge
    011150GS, no surge
    031150RT, minor surging, cure was easy
    04 1100S, no surge
    May 2006
    grove city,pa
    BMW told me that they did not surge, yep!!
    Oct 2011
    I would simply say, yes, they do. However, the fix is so easy that I would not hesitate to purchase the model you like best. And when you fix the underlying cause of surging, you get a big torque pickup between 2000 and 4000 RPMs.
    Apart from normal maintenance, including a throttle body balance two more steps transform the R1100s and r1150s:
    Clean the injectors and have them flow tested for balance .
    Richen the closed loop AFR target with a Wideband O2 sensor like he LC-1 or one of the plug 'n play narrowband lambda shifters which will come on the market this year. (One of which I'm test riding now.)
    RB
    Badger
    Jun 2006
    Twin Falls, ID
    Many Thanks!
    I really appreciate all the great input I got here ref the surging in single spark oilheads. Think I'll get on here more often to garner the vast experience of many riders. Mike.
    Curmudgeon nrpetersen's Avatar
    Sep 2004
    minnetonka mn
    My 2000 R1100RT was fine when new but gradually developed a viscous surge by 20,000 miles. Multiple attempts to get rid of this following other published procedures went nowhere, although I did not try disabling the cat plug or other processor controlled functions. After all, the system worked once, so why couldn't it work again?
    My hunch was that surging could be caused by one cylinder (most likely the right one) dropping out from either too rich (unlikely) or more likely too lean operation at near closed throttle. The fuel injector pulse lengths are identical so the problem had to be in the airflow measurement and delivery system. The processor optimizes the fuel injector pulse length with the airflow as measured on the left with the throttle position sensor, but it also has to assume that the right airflow vs left TPS output voltage is close enough to the left side that a combustible mixture is assured on the right side. At high throttle openings this is reasonable to assume, but at small openings it depends on the equality of the BBS settings and the throttle stop screw settings, either of which can be affected by contamination, and both of which are functionally a setting trade-off.
    BMW says not to mess with the throttle stops (an EPA certification requirement?), but the relationship of equal airflow to the single-TPS output on each side won't necessarily hold when there are two sources of air to each cylinder.
    The acceptable range of combustible mixture is much wider than the 4% number suggested above, as poor carburetors and automatic chokes have proven for many years. According to Marks Engineering Handbook, it is over 2:1 ( i. e. 7:1 to ~19:1 A/F ratio). In other words, in our case, if the L-R airflow inequality exceeds ~2:1, there will be a right side miss - and I contend that is the source of the surge.
    This approach completely eliminated the surge by carefully adjusting the intake valve clearances, thoroughly cleaning the throttle bodies and BBS ports, and resetting the throttle stops & big brass screws (BBSs) to equal positions. It was not necessary to disable or change any of the processor controlled mixture functions at all.
    In summary, surge in my case was caused by an imbalance in the throttle stop screw /BBS settings created by throttle body contamination.
    Retired w 2005 K1200LT, 2000 R1100RT, & 1975 R90/6
    Mar 2010
    Vancouver, B.C. Canada
    Quote Originally Posted by nrpetersen View Post
    Interested to hear how you made sure the throttle stops and big brass screws were set to exact equal settings.
    The only way I know of unless you have a flow bench setup is to zero the left side then use the TPS voltage to set it up for idle and then use vacuum to make the right side match the left side. All of this is done with the BB screws turned all the way in so they don't affect the initial zero zero procedure. Then turn them out to the factory setting of 1.5 turns out and again use vacuum to balance both sides followed by a throttle cable adjustment at higher RPM.
    I've tuned 1100 engines pretty well using this method but never completely eliminated the dreaded lower RPM lower gear surge.
    Pepperfool GSAddict's Avatar
    Feb 2008
    Sechelt, British Columbia
    But did you do a flow test on your injectors first? Dirt can easily affect flow & pattern. AMHIK
    You say the surge developed so I assume it was not there originally. One injector not matching the other could easily cause your symptom. I would do that LONG before I messed with the stops. They are set at Bing on a flowmeter.
    Don't encourage messing with those screws as most that lack the experience would be tempted to adjust them and most probably make matters worse. Especially if they did not have the required instruments.
    Ufda happens..........
