Results 1 to 14 of 14
Thread: Correct tire for a 82 R65LS
    S\E Indiana
    I am getting this bike back on the road after sitting in storage, it only has 12,000 miles on it now. The tires have got to be older than 2000 if i read the DOT correct. The ft tire reads 3.25 S18 which i think is a 100 90 18 and the rear is a 4.00 S18 = 110 90 18 , which brand and type would anybody recommend to put on this bike. I weigh in about 225 lbs and this bike seems to be one that you might try to hot rod just a little so a sticky tire might be in order.
    The correct tire is the inch-sized tires, although people do use the metric tires. They're really not equivalent as the overall profile of the tire will be different. But people do use the metrics.
    The 3.25 number is the width...that would translate to 82+mm, so I don't think a 100 tire would work there at all. 4.00 translates closer to 100mm not 110mm.
    A few recent threads on tires...look through some of the past posts to find those discussions.
    S\E Indiana
    I just looked at Motorcycle Superstores webb site and it showes both sizes the 3.25 and 4.00 and also 100 90 and 110 90 so which way do i order?
    Eastern KY
    I suggest that you google something like "motorcycle tire size charts" and "motorcycle rim size charts". There are lots of them out there & some are better set up than others. www.central-wheel.co.uk in the UK has lots of rim info on their site. Look at several sellers as the prices vary quite a bit. My R65ls came out with Continentals that are unobtanium now.
    got, got, got no time... rguy's Avatar
    Aug 2003
    Rogersville, MO
    Avon Roadriders
    90/90 x 18
    4.00 x 18 Rear
    These sizes are about as close to OEM as you can find. I experimented with wider sizes and was unhappy with the handling and turn-in.
    Neal - '09 R1200GS / '81 R65
    _______________________
    Be the person that your dog thinks you are.
    Jul 2006
    Bath, Mi
    82 R65LS tire size
    Front 325 18 or 90/90/18
    Rear 400 18
    jgp
    Quote Originally Posted by ind1mrg View Post
    Order the inch sizes as they are correct.
    You know, lots of places in Europe it would be illegal to fit the metric size tires as they are not manufacturer approved.
    As was pointed out, the metric sizes are NOT equivalent and that notion should be abandoned.
    No longer a member here
    Well, he is South Indiana, so the things people in Europe are required to do may be of little concern to him.
    I am a member in the ICOA (International CBX Owners association) and we have the same issue with tires all the time. The first year CBX came with a 3.50x19 on the front and a 4.25x18 on the rear. Nobody I know uses the original tire configuration anymore as there are better tires available in metric sizes. Most tire manufacturer websites have conversion tables available that list the metric equivalents for the "inch" dimensions.
    Inch-size tires are readily available in the US, esp. for the 19-inch front and 18-inch rear wheels. Not sure about an 18-inch front, though.
    Aug 2003
    Rogersville, MO
    Inch size 18" front bias tires are about rare as hens teeth anymore. Michelin, Continental and Metzler are the major European tire manufacturers. They all recommend 90/90 x 18 front. Go to their websites and check for yourself. If they were illegal in Europe they probably wouldn't list them. Metzler makes the ME11 in 3.25 if you really really want the 'classic' styling. The ME11 3.25 is approximately 89 width compared to 90/90 is 90 width (duh). Trust me - the 90/90 is nearly identical to the OEM. And, yes, install tubes - even if the sidewall says tubeless.
    Dec 2007
    Reno, NV
    Question
    Quote Originally Posted by RGuy View Post
    Doesn't the LS have "K" bike wheels which can run tubeless?
    S\E Indiana
    Quote Originally Posted by jforgo View Post
    Can this be, mine right now has what looks like a tube comming out of the rim? I believe i have what is called the snow flake rim, looks like it could go tubeless.
    Aug 2003
    Rogersville, MO
    Many people run snowflakes without tubes and are happy - they say they work fine. Some also say they slowly leak air and you need to be diligent about checking your air pressure. The bead area of the snowflake really wasn't designed for tubeless tires. Because of that, some believe a sudden impact like a pothole could greatly increase your risk of sudden loss of air (similar to a blow out). Pretty much all of the manufacturers recommend tubes (for liability reasons I'm sure). That's all of the pros and cons I can think of at the moment.
    Dec 2007
    Reno, NV
    These original "LS" wheels sure look k-bike, and therefore tubeless (?) to me:
    http://www.bmbikes.co.uk/specpages/R65LS.htm
