Results 1 to 9 of 9
Thread: 1985 R80 won't down shift unless I blip the throttle
    Registered User jimbc's Avatar
    Jun 2012
    Ontario, Canada
    Starting last season my 85 R80 won't down shift unless I blip the throttle. I'm the original owner and have never experienced this before. Anyone know why? Thanks.
    jdubeemer jdubick's Avatar
    Boaz Alabama
    Quote Originally Posted by jimbc View Post
    I have a 78 R100/7 and was having the same problem. You need to have your splines lubed. You have to back the transmission out to get to the splines in question. There is probably a link in the forum for the procedure or you can contact your favorite Beemer wrench. Should clear it up.
    Jim Dubick
    Boaz, Alabama
    R1200RT,R1100GS,KLX250
    BMW MOA, BMW MOALABAMA
    Jun 2012
    Ontario, Canada
    Thanks for the info, Jim
    Apr 2012
    Gilbert, AZ
    Here's a spline lube tutorial with pictures:
    http://www.webbikeworld.com/t2/spline/
    Or here's Snowbum's article. More verbose but quite thorough:
    http://bmwmotorcycletech.info/inputsplinesthrowout.htm
    My RS was shifting rough & hard to find neutral, etc. A spline lube made a world of difference. Be sure you clutch is adjusted properly, too:
    http://bmwmotorcycletech.info/clutch.htm near the bottom.
    2004 R1150RT
    BMW MOA 181289
    Jun 2012
    Ontario, Canada
    Thanks for that Mark
    nc bmw driver
    Here are some very good videos on how to do a spline lube.
    http://www.youtube.com/watch?v=uVKPGcf0xag
    http://www.youtube.com/watch?v=p8dJzD42eYI
    http://www.youtube.com/watch?v=p0Kw38blwfg
    http://www.youtube.com/watch?v=qXXnNQf2F_k
    There is some colorful language used, but very good detailed information provided.
    Regards
    Jun 2012
    Ontario, Canada
    Amazing what can be found on the net. Thx
    ...and here's some more "amazing" things that be be found on the net...
    http://forums.bmwmoa.org/showthread....rces-and-Links
    Pismo Beach, CA
    ... nice seque Kurt
    Lew Morris
    1973 R75/5 - original owner
