Results 1 to 11 of 11
Thread: Camp stove fuel availability
    Lost again Texpaul's Avatar
    Oct 2006
    San Antonio, Tx
    This question is regarding the availability of the female linden valve isobutane/proapane canisters, (like MRS or Jet Boil) on the road. I know if you can find a big box sporting goods or Walmart you can find them, but I'm curious about in less populated areas without all the conveniences of modern consumerism.
    Paul Mulhern
    MOA# 56330
    The biggest mistake people make... is thinking they have time.
    jeepinbanditrider
    I'm usually not out of an area that doesn't have a wal mart for long enough for it to matter. I carry two isobutane fuel cannisters. I'd have to be out and about away from cities for a pretty good while before I ran out of gas. You're usually never very far from a wal mart anyway, anywhere in the US. And I've found that some smaller mom and pop country stores that are a towns only source for groceries and whatnot sometimes carry the fuel canisters.
    Registered User brewmeister's Avatar
    May 2009
    along the wisconsin river here in central wisconsin
    That's why I use the onepounder propane cylinders,I'll stop at any gas station and buy one before stopping for the night so I carrie it the least amount of time on the bike.
    jeepinbanditrider
    Quote Originally Posted by brewmeister View Post
    Those won't attach tot he small single burner stoves that use the isobutane mix fuel. Unless there's an adapter out there somewhere but then I don't know how the performance would suffer.
    Edit-
    http://adventuresinstoving.blogspot....g-adapter.html
    Might pick one of those up and see how it works.
    BMW Motorcycle Owners rdalland's Avatar
    May 2006
    of America
    Quote Originally Posted by Texpaul View Post
    No worries...there's a cannister for that.
    ride what you've got; enjoy the ride!
    Reid - Stone Ridge, NY - BMWMOA #69187 - Turbo Fluffy Motoclub - IBA #50182
    Registered User argent brick's Avatar
    Aug 2012
    Wine Country, Northern California
    Should not be a problem. Just make sure that you have one extra canister of fuel on the bike. Knowing how much fuel you normally use for a meal will also give you some peace of mind. The canisters come in more than one size, depending upon the manufacturer.
    You might want to check out different brands of fuel. Some are blended differently and work better in cold weather or higher elevations.
    That Kovea adapter looks like something I would buy, but I can see a potential problem with pot stability when you use a bigger fuel bottle.
    Lynn
    MOA #57883
    Current Ride: 1995 K75 Standard
    Past: 1978 Yamaha XS 750, 1976 BMW R60/6
    Polarbear Polarbear's Avatar
    Clovis,CA
    My JetBoil options;
    They sell three different size gas bottles, from mini to really large ones and you could/likely never run out of burn, carrying two of these or even one with alternate stove! My alternate is the Pocket Stove with tablets and its so tiny, takes up no space to pack. The tablets burn 12 minutes each and boil water, 16oz in 2 minutes. Full pot(32oz) in 5 minutes to a boil. Blow'em out, reuse whats left. The JB of course is a BLAST furnace and cleaner. The tablets burn clean too, but a slight residue on pots washes off easy. I carry both stoves. Anybody cooking on a JB, has learned something about heat and control to NOT burn up a meal. A defuzer panel on these stoves helps a LOT to control heat and makes cooking a tad easier on the JBs. Ask me how I learned this! My diamond plate sidestand skid works perfect. Randy
    Eastern KY
    If testimony is what you want, I can truthfully say that I have walked into box stores(Kmart,Walmart,etc.) in areas of all sizes(and to include areas where far more people camping then most places) & not been able to buy the small canisters. Like they say"don't leave home without..."
    "If I had my life to live over, I'd dare to make more mistakes next time...I'd relax,I'd limber up... I would take fewer things seriously...take more chances... take more trips...climb more mountains...swim more rivers...eat more ice cream." Jorge Luis Borges at age 85.
    Oct 2006
    San Antonio, Tx
    Quote Originally Posted by ARGENT BRICK View Post
    The Kovea adaptor is what I've been looking for, thank you. I thought something like that existed just wasn't sure what it was called. With this I can run the small linden valve canisters when I can find them but still be able to use the larger propane bottles when I can't. Yes, stability can be an issue but that is a much easier issue to deal with than a lack of fuel.
    ARGENT BRICK you should send the Kovea adaptor info into Kevin Greenwald for the Touring Tips column in the ON.
    Thanks to everyone for their assistance.
    Paul Mulhern
    MOA# 56330
    Aug 2012
    Me? Why me? I can't take credit for the the Kovea adaptor. I did not find it, someone else did. I will be picking one up though.
    Lynn
    MOA #57883
    May 2006
    of America
    Quote Originally Posted by kantuckid View Post
    Click Here.
