Results 1 to 5 of 5
Thread: 2005, R1200RT + Flash2Pass install?????
    Registered User Spinakr's Avatar
    Nov 2007
    Vancouver... Not B.C... Washington... Not D.C.
    Has anyone installed a flash2Pass transmitter on an R1200RT?
    I really can't see how I'm going to tap into the high beam wires off the back of the bulb.
    There's just no room to shove the Flash2Pass transmitter in there and get the cover back on.
    Plus, I only have about 2 inches of wire behind the bulb plug to work with.
    HELP!
    Vancouver, WA
    BMW MOA #136722
    Registered User Atomicman52's Avatar
    Jun 2009
    You don't put the transmitter in there with the bulb. . just tap the wires and replace the cover then tape or strap the transmitter to anything you choose under the dash.
    My works like a charm! Since there is a rubber gasket around the headlight cover, the wires will fit between the cover and the housing with the cover tightened w/o a problem.
    "The Older I Get, the Faster I Was"
    '09 Black Metallic Sapphire "Fully Farkled" RT
    Nov 2007
    Thanks Atomicman52.
    It was looking like that was my only option.
    Rob.
    Vancouver, WA
    BMW MOA #136722
    Jun 2009
    Quote Originally Posted by Spinakr View Post
    Thanks Atomicman52.
    Rob.
    You're Welcome, it's still a bitch to get to the wires and tap 'em but doable, barely!
    Nov 2007
    Tried something different
    I had a REAL hard time trying to get the supplied connectors onto the wires coming off the back of the high beam plug.
    So, I took a couple of male spade connectors, then, using a couple of pairs of small needle-nose pliers, put a couple of bends in them. The connector wound up looking a little wavy. There is just enough room on the back of the bulb connector to wedge those spade connectors in pretty snug, then bent the wires down and put the cover back on. Voila!
    Works like a charm! I guess if they come out I'll try the wire connectors again, but for now they're in pretty snug and the back cover pushes against the wires directly into the back of the connector.
    Rob
    Vancouver, WA
    BMW MOA #136722
