Results 1 to 5 of 5
Thread: 2003 K1200GT Headlight Bucket
    Oct 2011
    Ohio
    I found out today that one of the mounting ears was broken off of my headlight bucket. Someone had tried to repair it with some type of epoxy. I have had the bike for over a year and a half and it just let go today. Has anyone had any luck repairing something like this? Can I expect something like JB Weld to hold up? Any other ideas?
    Beemer Boneyard is out of stock for a used one. I have emailed re-psycle to see if they have a used one. Any other places to look?
    Thanks,
    Jeff
    93 K1100LT
    03 K1200GT gone but not forgotten
    14 Victory Crossroads
    Debbie's Servant Lee's Avatar
    May 2003
    SW Iowa
    If you're talking about part # 11, it's less than $19 from BMW.
    If you're talking abut # 1, lets hope you find a used one.
    Lee
    2016 R1200RS
    MOA # 30878
    Oct 2011
    Ohio
    I wish it was #11. Could probably come up with a functional repair for it.
    If I fail to find a used one I plan on forming a bracket out of aluminum. It will give a larger surface to glue to. Still not sure how well it will hold.
    Jeff
    93 K1100LT
    3 Red Bricks
    Jan 2007
    Pleasanton, Ca.
    Jeff,
    PM sent.
    LONG MAY YOUR BRICK FLY!
    Lee Fulton Forum Moderator
    3 Marakesh Red K75Ss
    Mine, Hers, Spare
    Oct 2011
    Ohio
    Well, I went ahead and cobbled up a repair. Most of the old epoxy just scraped off with a fingernail. I used a razor knife and a pick to get all of the old stuff out of the nooks and crannies. After cleanup, the broken tab nested in nicely. I used Permatex brand plastic weld for the repair. A real thin layer was applied to the broken edges and then I held the tab in place until it setup enough to stay.
    Next I fashioned a piece of light weight non-ferrous gray stuff into a wrap around support. After scuffing everything with 36 grip emery, the aluminum was glued into place with the same plastic weld. The container said I could use it on the aluminum. It's not real pretty but I think it will hold up better than the last repair.
    Still have to do some cleanup and drill the hole through the aluminum. Figured I should wait until it is fully cured to do those tasks.
    Jeff
    93 K1100LT
