Results 1 to 2 of 2
Thread: Clutch pushrod w/felt install
Hybrid View
    BMWJean
    Aug 2009
    Freedom, WI
    Question Clutch pushrod w/felt install
    Hey Airhead knowledge base:
    Just installed a new felt on the clutch push rod for my 78 R100S.
    Rubbed a bunch of grease into the felt, wrapped it around the rod tightly and inserted it ,starting it from the front side of the splined input shaft. (Sno Bum has written it's easier to install this way.)
    The rod went in until about a quarter of it was left poking out of the input shaft and met with some resistance where the felt was about to start engaging with the sealing surface.
    I wasn't able to push it in the remaining distance by hand, so I used a plastic tipped hammer and gave the rod a light tap.
    This seemed to work and the end of the rod is now flush with the end of the input shaft. I then tried pushing the shaft from the back side of the transmission using my thumb and was able to get the rod to extend out of the input shaft by about 1/4". (The end of the tapered part of the rod is flush with the input shaft...if that makes any sense.)
    My question is, before I continue installing the throwout assembly, is there any way of testing to know if the felt is properly in place?
    How far does the push rod normally extend from the input shaft to engage the clutch spring? Is there any way to test this whole assembly before installing the transmission?
    1978 BMW R100S- My current money pit...uh, project.
    2007 R1200S
    1990 BMW 325is
    2007 Z4 M Coupe
    Jun 2007
    Minneapolis, MN
    Quote Originally Posted by bmwjean View Post
    I just went thru this process last week on my R60/5 - pushrod went in from the front. Was advised to apply a small amount of Honda Moly on the tip of the clutch pushrod that comes into contact with the pressure plate. Packed the parts closed to the clutch lever with grease. Just referred to the Haynes & Clymer manuals (never had done this job before). Didn't test until after installing the transmission, attaching clutch cable and actuating clutch lever, while tranny in gear to see if I could rotate the transmission output flange that attaches to the driveshaft.
    Ken Tuvman
    Excelsior, MN
    K75s, R65LS, R60/5
