Results 1 to 3 of 3
Thread: Shock Installation
    HOTTECH
    May 2008
    Concord,N.C.
    Shock Installation
    I bought a pair of stock shocks to replace my stocks off my 2004 R1150R. I know that ?hlins USA has a damper control and rebound adjustments that need to be made after installion. Is ther any adjustments to my stock Skowas that need to be made or are they just a plug and play stock shock?
    MOA #24991 Pauls1150's Avatar
    south of Los Angeles
    Plug'n'Play...
    If there is a little screw adjustment on the side of the bottom eye, that's rebound damping, set it to LIGHTLY seated and then 1/4 to 1/2 turn out. "Out" is softer; more than 1/2 turn out makes no difference (out of range).
    Live the Dream JRD's Avatar
    Jul 2003
    SW Ohio
    Regarding the rear shock, the little r1150r owners manual says 1-2 turns out on the screw adjustment for solo riding and less for two-up.
    Joe DeLuca
    SW Ohio USA
