Results 1 to 7 of 7
Thread: Michelin Anakee 3 install feedback
    Was going to post in Hexheads in one of the tire threads...but not just a one model tire.
    Mounted a set of Anakee 3's on a buds GSA yesterday...woof! The owner is a LD/IBA rider and will give some tire performance soon.
    These tires were some of the hardest to install, thought I was putting a ME880 on a LT or a Wing! Have many sets of tires installed to compare to in effort...these were way high on the effort needed.
    The air temp was around 50 and we set the tires on a sunny surface to warm them up prior. Using a NoMar machine, still needed the spoon bars to flip the last bit of bead in place. The sidewalls seem to be way stiffer than previous generations of the Anakee's...which I believe I read somewhere as well.
    I'll get another try in a few week when I install the set I have for my bike. Haven't worn out the PR3's quite yet.
    If you are installing on the floor with small tire irons...have fun
    Steve Henson
    Registered User rebake's Avatar
    green valley,il
    milage on the 3's?Thinking about them for my gs12.Ed
    Ed Baker
    Just mounted a set on my 04 GS, didn't think they went on any harder than then A2's. Did it in a heated garage but the the tires were cold. Very interested in the milege I'll get from them, the set of A2's that came off had 13,500 miles on them and just hit the wear bars. Looks like the A3';s should be a smoother road tire. The temp's ( Pa. ) are to be in the 50's this weekend and I should be able to try them out.
    Quote Originally Posted by rebake View Post
    Too early for any feedback from instalee.
    Tire wear is touted as "improved" from A2's in the marketing hype.
    I see some guys go as far as tomtietjen...but for me, never got over 8-9K on the rear...maybe an occasional 12K on the front. When I used Tourances...I had no rear tread after 6K on average on the heavy GSA. On the F650 Thumper...they keep on going
    It's all about road types and rider style...to many variables. RoboRider and pffog shred tires even faster than I do.
    I change mine when the bike tells me it's not happy in the twisties or rain
    for those who have not seen the difference in the tires, here is a side by shot. The 3's are in the center
    Steve Henson
    I have a pair of A3's to tear up in the Smokey's at the end of April, we will see how they do. The 800GS being lighter than the R11S was, I am expecting better tire life. I will see i I can be the first to burn off a set
    '01 F650GS Wife's bike
    Maritime Alps and Vosges 2012
    Quote Originally Posted by pffog View Post
    knew I could count on you
    Steve Henson
    I just put on an Anakee 2 yesterday and like the one I put on before, getting them on the wheel wasn't an issue, getting them to pop into the bead was a super b-tch. It was between 40 and 45 degrees and I started on Saturday and didn't get it to pop until Sunday evening. Took it totally off and re-lubed it a second time. Took it to a tire store for a higher capacity air compressor. Nothing was working. Took it in the house and put it in front of the fire place and got it up to about 75 degrees. That didn't work either but I think it helped with final solution. Took a squeeze bottle filled with GoJo that had a long pointy end on it and shot the GoJo right in between the rim bead and tire. Used a small brush to put the GoJo deeper into the gap between the tire and rim. FINALLY, it popped. Anyone know if the wire wheels are harder to mount than the cast wheels???
    Old But Not Dead
    Semper Fi
