Results 1 to 3 of 3
Thread: Camshaft woodruff key sizes
    Registered User kwb210's Avatar
    Jul 2009
    Washington, the state
    Camshaft woodruff key sizes. I have a 1974 R90 with a nutty history, another story, and the camshaft needed to come out because the PO used brute force when over tightening the small nut holding the advance unit on. He broke off the end. The cam I removed has a much larger keyway, maybe 25% longer, than the camshaft I thought I would use to replace it. And of course the woodruff key is larger both in length and just slightly wider. I think later in the airhead engines they did away with the key and the end of the cam is slotted. My question is how do I find a cam that will fit? What years did they use different keyways?
    Regards,
    Kurt
    1977 R100/7 1971.1972.1972.1973 R75/5
    1974 R90/6 multiple boxes
    Airhead Revival
    "Objects in the mirror appear to be losing" unk
    Administrator 20774's Avatar
    Kurt -
    I'd suggest going to RealOEM and put in your bike and find the woodruff key...it appears to be part 07119951480 and the fiche gives the info "5x6,5". Using that part number in a reverse search on RealOEM and see the other applications. I did and it shows it be a common part on many models, mostly /6 and on. However, by looking at the R75/5 it shows the same part number.
    Jul 2009
    I forgot about RealOEM, thank you! I am really wondering when they made the change to a larger key. The "replacement" I have is really a small little key, considering it's job of turning the oil pump I can understand the engineers bumping up the key size to make it a bit more robust. "Bumping up the key size" is probably not a common engineering verse!
    Thanks for the lead on tracing this size thing down. I'll post what I find.
    Regards,
    Kurt (great name)
    Airhead Revival
