Results 1 to 6 of 6
Thread: Mounting Sena smh 5 in helmet
    Apr 2005
    Michigan's Upper Peninsula
    I just purchased a New Aria Quantum helmet. I also purchased the sen a smh 5 unit. Does anyone have any experience mounting this unit in an Aria Quantum helmet. How the speakers go in? Do you have to cut out part of the padding in the helmet? Help would be appreciated. The liner is removable. Any recommendations?
    All-round Motorcyclist MarkM's Avatar
    Dec 2010
    St. Louis
    I've got a Sena SMH10 mounted on an Arai Profile, so maybe it's similar to your setup. My helmet speakers have Velcro hook material on the backs and I've got mine stuck directly to the surface of the liner. I did not modify the helmet or liner in any way. It works fine for me.
    Name:  2013-03-08 00.36.37 (800x600).jpg
    Mark M, St. Louis, '13 R1200GS
    There are two roads in life; the dirty one is vastly more fun.
    Apr 2005
    Sena 5
    Took your advice and it works great. I did this before with a J&R headset but had to cut some of the insulation out. This was a snap. Thanks for the recommendation.
    Dec 2010
    St. Louis
    Great. Glad to know it.
    Nuckin' Futs! tonyfr's Avatar
    Apr 2007
    SAT - LAX
    Quote Originally Posted by MarkM View Post
    I mounted my SMH10 speakers the same way in a Shoei RF1000 helmet. It fits a little tight and I have to wear a helmet silk so the speakers don't rub on my ears. Other than that, it fits okay.
    SABMWRA MOA #62
    2005 BMW R1200RT
    1984 Kawasaki ZX750-E1 Turbo
    Aug 2005
    Charlotte, NC
    Ummmmmm, guys (or gals)
    the Arai has speaker pockets. All you have to do it take out the same padding that you attached the speakers to. There is a place to permanently mount the speakers. Just make sure that the speakers are aligned directly with your ear canals. then run the wires along the bottom of the helmet to the unit itself.
    easy-peasy....
    Enjoying the ride, but always on the alert for a rally.......
