Results 1 to 8 of 8
Thread: '03 R1100S Heated Grip Replacements
    Left Coast Rider
    Nov 2011
    My bike has the newer style heated grips. They are about worn out and I want to replace them. Apparently, if I want OEM, I need to replace the whole kit AND the kaboodle (grips and heating elements)
    Is there an alternative?
    Thanks in advance for your input/snarky remarks.
    All-round Motorcyclist MarkM's Avatar
    Dec 2010
    St. Louis
    Ted Porter's Beemer Shop sells just the grips for $20. BMW Heated Grip Replacement
    Mark M, St. Louis, '13 R1200GS
    Left Coast Rider
    Nov 2011
    Quote Originally Posted by MarkM View Post
    You, sir, are a man among men.
    Apr 2006
    Any dealer can get them , you need 2- part # 32721458396. They are listed as the RH grip for a K-1. I put a set on last summer on my S
    2010 F800GS Full Ohlins package, '04 R1100S Replika
    '01 F650GS Wife's bike
    Maritime Alps and Vosges 2012
    Tuscany and Central Italy 2010
    Mar 2010
    Vancouver, B.C. Canada
    Dealers always go for replacing the entire assembly. Quick and easier but also much more expensive. Dealer list is $12.76 at RealOem so Ted Porter's price for two is a deal. The grips also fit quite a few other bikes with heated grips. Interesting the R1100S is not listed.
    Part 32721458396 (RIGHT GROOVED HANDLE) was found on the following vehicles:
    259E R 1100 GS 94
    259R R 1100 R 94
    259R R 850 R 94
    259S R 1100 RS 93
    259T R 1100 RT 96
    89V1 K 100 RS
    89V2 K 1100 RS
    Albuquerque, NM
    Well, gee, how about a link to actually how to do it?
    http://www.advrider.com/forums/showp...61&postcount=1
    Kent Christensen
    21482
    Mar 2010
    Here's a tip on a MUCH easier way to remove old grips. Follow the instructions lkchris just posted a link to but ignore the grip removal instructions. Instead gently force a small opening in the outer end of the grip, get out your air hose gun and shove the nozzle in between the handle bar and the grip and blow air in there. You may need to reposition the air nozzle from top to bottom once or twice to completely loosen them off. Twist and remove as you go. They will come off easily, quickly and this method does not damage (slice?) anything unlike most methods described elsewhere. Utility knives and heated grips do not get along at all. DAMHIK
    Left Coast Rider
    Nov 2011
    As usual, a huge amount of great data here. Thanks! BUT......
    What if I want the same style original grips which came on the bike? Mine don't have the multiple grooves along the grip. Those are the early model. Who here has the part # for the later style grip?
    Looks like the upper grip in this illustration: http://www.ascycles.com/Illustrated_...indCat=32_0955
