Results 1 to 4 of 4
Thread: Touratech Top Case Modification
    Registered User mtzgrr1951's Avatar
    Sep 2011
    Lightbulb Touratech Top Case Modification
    Anyone else out there troubled when you close the Touratech Top Case and you pinch the stop cable between the body of the case and the top? I was. Here is my small and inexpensive modification to stop the pinch!
    Go to your local hardware and purchase a light-weight 2" spring that expands effortlessly to about 4 inches. Replace the hinge bracket screw with a screw that is about 1/4 inch longer so you have enough room to place the spring, a washer and a nut over the end of the screw. Obviously, attach the other end of the spring to the lid stop cable.
    Works perfectly.... as you close the lid the spring will gently pull the cable toward the inside of the case.
    Registered User Kevster's Avatar
    Jan 2007
    Behind the 9/11 Flightcrew Memorial
    Nice idea
    Glad I looked at your thread.
    Calgary
    I did exactly the same thing with my BMW Adventure cases which use a similar cable stay (and are made by Touratech for BMW). It does work very well.
    Ed Miller, Calgary, AB
    2008 K1200GT, 2009 F800GS
    I can't wait to retire and have a fixed income. The one I have now is always broke.
    The Big Red One sgtbill's Avatar
    Jul 2006
    Herndon, VA
    I just removed the cable on the lower side (when parked on side stand). Having only the other cable works fine for the purpose and removing the other eliminated the pesky cable pinching that happened.
    sgtbill
    Duty First!
    86 K100RS EML & 79 R100S
    2007 F800ST & 2014 F800GS & 2014 F700GS
