Page 2 of 2 FirstFirst 1 2
Results 16 to 21 of 21
Thread: Oilhead fuel filter equivalent? 2000 R1150GS
  1. #16
    MOA #24991 Pauls1150's Avatar
    Apr 2008
    south of Los Angeles
    The search engine seems to have been cut short with the new forum setup, so -
    Here's my setup; the filter is a WIX p/n 33032, rated for everything from a four-cylinder Toyota up to a big honkin' V8 Caddy; available at many auto parts stores for about $5.
    Don't forget to change the filter on the intake side of the fuel pump too - water or particles in the gas can kill the pump. There is a non-BMW alternative to that too but I don't have that info handy.
  2. #17
    Apr 2008
    And here's the clip that mounts it to the top of the air filter box; no I don't have a part number fer that either...
  3. #18
    Eastern KY
    I routed mine "in one side , out the other" which is no big deal & use the same filter but a SS clamp with a hole in the bottom for the same screw. Simple variations to consider but same result: cheap,easily changed filter with more lines giving tiny bit of new fuel capacity.
    "If I had my life to live over, I'd dare to make more mistakes next time...I'd relax,I'd limber up... I would take fewer things seriously...take more chances... take more trips...climb more mountains...swim more rivers...eat more ice cream." Jorge Luis Borges at age 85.
  4. #19
    Apr 2006
    maine
    Another option showing external fuel filter with clamp and hose routing. I tried installing fuel filter below throttle body but then was unable to get side fairing panel back on without forcing. This install allows easy access behind small black panel cover.
    Mark
  5. #20
    DBLUPPR snookers's Avatar
    Jul 2010
    Southwest of Beamsville
    External Fuel Filter Install
    While performing some wintertime maintanence on our 1100RT, I removed the OEM filter, and replaced the filter void with a length of 5/16 ID tubing. Also replaced the 180 degree hose with the flex line from euromotoelectics.com .
    The new filter was installed behind the rear black plastic cover along with new fuel injection rated fuel lines. Now the filter has easy access when it needs to be replaced.
    As I was unable to get the fuel filter of choice, a WIX 33323 filter, a Luber finer FF733 filter from Autozone was installed . Same filter, different manufacturer.
    2000 R1100RT
    Niagara BMW Riders #298
    BMWMCO #45
  6. #21
    RK Ryder
    London, Ontario
    Snookers,
    I like your fuel filter. It appears to make running the in and out fuel lines a much simpler and compact hookup than mine.
    Paul
    Knights of the Roundel #333
