Results 1 to 15 of 21
Thread: Oilhead fuel filter equivalent? 2000 R1150GS
    Tried search and got nothing... maybe someone knows.
    Dealer price for fuel filters is $35... insane.
    I've seen the outside the tank option, but is there an auto parts store equivalent for use inside the tank?
    Thanks in advance.
    Ian
    RK Ryder
    London, Ontario
    I don't know about the 1150GS, but my K100RT and my R1100RT both use the same fuel filter, NAPA Gold 3032, which I believe is in the $5.00 - $6.00 range. I use the NAPA Gold inside the tank of the K, but since moving the filter to outside the R's tank, and the BMW filter has a higher PSI, use the BMW filter on that bike. Hope that helps. I thought that the 1150s didn't come out until 2001.
    Paul
    Knights of the Roundel #333
    Same filter for R1150s as for R1100 and K bikes.
    Paul, I am curious. Why would you want to use the high pressure filter on your R bike when it sits outside of the tank, but not find it necessary when it sits inside the tank? A ruptured fuel filter will not work and will leave you stranded, regardless of it's location.
    Less expensive sourcing.. http://www.beemerboneyard.com/16142325859.html
    ah, jeesh... why didn't I think of beemer boneyard?
    According to the parts fiche at Max, 1150GS was available as early as 1998. I bought mine in July of 2000.
    ian
    RK Ryder
    London, Ontario
    I just assumed that if the fuel filter should burst and if it's inside the tank, then the fuel will be contained as compared to when outside the bike, possibly spewing gas all over the place. Changing the filter on the K is relatively simply, even with it in the gas tank.I didn't realize that a ruptured fuel filter would not be messy.
    I never had a problem, but an additional fuel filter is one item I carry with me when travelling, just in case one is needed.
    Paul
    Debbie's Servant Lee's Avatar
    SW Iowa
    Quote Originally Posted by Visian View Post
    Check the ON magazine, they used to give MOA members a 10% discount.
    Lee
    2016 R1200RS
    MOA # 30878
    DBLUPPR snookers's Avatar
    Jul 2010
    Southwest of Beamsville
    Paul.....if you can......would you be so kind as to show us some pics of your external fuel filter ......I have my tank off the bike at the moment and am planning on changing out the fuel filter.....some further insight is appreciated
    2000 R1100RT
    Niagara BMW Riders #298
    BMWMCO #45
    Quote Originally Posted by snookers View Post
    you'll want both this one, and its embedded one.
    http://www.ibmwr.org/r-tech/oilheads...RT/index.shtml
    (i guess posting the link would help, eh?)
    RK Ryder
    London, Ontario
    I can't really help you much for a couple of weeks or so until I take the Tupperware off the bike. I had an independent mechanic do the removal from the tank and install it outside the bike. It's been like this for a couple of years but this year I will loosen all of the ties to see if it can be moved a couple of inches closer to the back, to neatly tuck in behind the black plastic. If not I'll buy a new fuel line and extend it a bit further away from the tank. At the present time, it doesn't allow the black plastic piece to be snuggly inserted into place with the top front plastic bolt not totally secured. As well, moving it back a bit would allow one to not have to remove the side panel to get at it, which would be handy if it had to be changed while on the road. A friend has his tucked well in behind the plastic, as I recall, possibly above the rider's right foot peg. When the plastic comes off, I'll PM you show you more detailed pictures. I know that I have seen a thread on this on this site, but I am unable to find it today. For now, hope this gives you an idea of my setup.
    Cheers!
    Paul
    Paul
    Apr 2010
    Vancouver Island BC
    I just put a new fuel filter in my 1150 yesterday. I had changed the OEM at 45.5K miles with a Mann MKW44 from the Boneyard. Couldn't wait for one from them so after reading many threads I put in a Napa 3032 which cost all of about $3.50. Also replaced the big O ring was $10
    '64 R50/2 - "Gone But Not Forgotten"
    '76 R90/6
    '02 R1150GS Adventure
    Jul 2010
    Smile
    When the plastic comes off, I'll........show you more detailed pictures.
    Thankyou Paul.......
    2000 R1100RT
    BMWMCO #45
    see edited post #8. Directions, pictures, the whole shebang. And no waiting.
    RK Ryder
    London, Ontario
    The Internet BMW Riders site has good instructions, but I don't believe that it includes pictures. If you check this link, this thread does include pictures of a couple of different ways of doing this. Having found this link, I have now seen the fuel filter in four different locations, including my friend's which is mounted somewhere north of his right foot peg. I am not taking credit for the location of mine, but I think that it's location (with my modification this summer) should make it the second easiest to access. http://forums.bmwmoa.org/showthread....uel-Filter-Mod
    Good luck with your modifications!
    Paul
    Multiple pics are included as embedded links in those ibmwra writeups, including filter placement and fuel line routing.
    Eastern KY
    My outside the tank filter(solid steel Wally world variety) is mounted on the top of the air filter cannister and has a SS hose clamp holding it in place via a screw already found there. Handy/cheap solution.
