Results 1 to 15 of 15
Thread: Starting Problems
    Donmystic1
    Jul 2009
    Mystic, CT
    Starting Problems
    I have a 1977 R75/7 with 38000 miles.
    When I push the start button I get nothing.
    The battery is fully charged
    There are no broken wires that are readily apparent.
    Fuses look ok
    I replaced the starter solenoid with a new one.
    Prior to me replacing the push rod seals the bike started fine now I have lost a connection somewhere.
    Any ideas
    Don
    860-460-3282
    Administrator 20774's Avatar
    Do lights on the instrument pod operate normally?
    check the electrical ground
    check the electrical ground. go through everything you did, step by step and make sure it is back as it should be.
    Donmystic1
    Jul 2009
    Mystic, CT
    Starting problems
    Quote Originally Posted by BMWBubblehead View Post
    Everything else works as it should.
    I will have to trace the wires in the starting system.
    Kill switch?
    Minnesota Nice! braddog's Avatar
    Twin Cities - MN
    I had a similar problem on my '77 R100RS. Fully charged, newer battery. Turned the key on, everything worked except the starter button. Shorted the starter relay, starter turned over just fine. OK, so that means something between the relay and switch, right? Turns out a wire from the handlebar switch gear had gotten "stretched" so it was no longer making good contact. I had to repair/replace some the wiring from the switchgear on the handlebars, problem solved.
    Just thought I'd share in case your issue is similar.
    Brad D. - Member #105766
    '77 R100RS - Black Beauty (big pipe, baby!)
    '94 R1100RS - Sylvia
    Monza Blue 1974 R90/6
    Delaware
    Fortunately, as electrical problems go, the one you are having is generally easier because the circuit to the starter is pretty straight forward.
    However, one of the major points that keeps being validated on this forum is that an apparently fully charged and healthy battery is very often a problem.
    Can you jump the bike using another battery?
    What about checking for a voltage drop at the battery when you press the starter button? If it drops below 9 volts, that might not be enough to turn the starter.
    If the battery really is ok, then as outlined above, you can "jump" power direct to the starter and see if it turns. If so, then you can start working forward from the battery (or backwards from the starter) to find the disconnect.
    Common problem spots for a bad connection are the red wire connection at the starter relay and the red wire connection on the diode board.
    Good question (above) about whether you are having other problems like lack of dash/insturment panel lights with the ignition key on.
    Barron
    Pismo Beach, CA
    I'm guessing that the battery was disconnected before the push rod seal work was done?
    Lew Morris
    1973 R75/5 - original owner
    1963 Dnepr
    Had nearly the exact same problem with my 78 R100/7. I had just purchased it a month earlier, and barely rode it 100 miles due to the weather. Though my issue was cause by my putting it in gear before going into a restaurant (I didn't want it to roll) and when I came out, I forgot about that. Turned the key on, pushed the button, and nothing!!
    Then I remembered (it had been over 20 years since I had my previous BMW or any other bike) that it has a switch on the shifter so that it cannot be started in gear!
    Put in neutral, and away I went!
    Donmystic1
    Jul 2009
    Mystic, CT
    Starting problems
    I have the same problem as Braddog ( reply # 7 ).
    I jumped the starter with a screwdriver and everything is normal.
    Now I plan to cut into the wire cover coming from the starter switch and see if I have his problem.
    The easy thing would be to put a switch between the starter circuit and by pass the factory circuit.
    I spend a little more time before I do that though.
    Don
    May 2012
    VA
    Quote Originally Posted by Donmystic1 View Post
    Fuses look ok
    Any ideas
    Don
    860-460-3282
    Sometimes these forums are best used to point out the obvious:
    1. The bike started fine before you worked on it.
    2. Work was done.
    3. Now, the bike does not start - translated to mean the starter does not work.
    4. The bike's starter is not defective nor is the starter relay.
    Obviously, something changed when work was done on the bike. It would be wise to reflect on what was done that could possible have caused this problem. Good luck!
    Stan
    AH# 13238
    Donmystic1
    Jul 2009
    Mystic, CT
    Starter wont work
    When I did the push rod seal replacement, all I did was remove the heads pull the cylinder partially out, replace the seals and reassemble. I don't see any wires that were moved or disconnected except the spark plug wires and I have checked them.
    Cutting into wiring should be the last resort.
    First, check the safeguards. Bike in neutral, neutral light on? Clutch squeezed. When you press the button (in a very quiet room) can you hear the starter relay click, under the tank?
    If not, start to check the power flow. Power to the start button, from the start button, to the relay, etc. You can do this in the headlight bucket and under the tank without cutting into anything.
    Twin Cities - MN
    Correct. We did all of our troubleshooting with a simple circuit tester, we didn't cut into anything.
    Sep 2009
    north central ohio
    My '77 R100S had a similar problem, however it would start with the clutch pulled, so if you are certain that function always worked in the past then ignore this.
    There is a diode on the terminal board (not the diode board) that can fail. It is a bear to get to at the back of the headlight bucket. The Haynes wiring diagram shows this on terminal 85B. FYI my neutral light did work also. Guys at RePsycle walked me through this problem!
    I believe you should be able to test the diode function without too much disassembly?
