Results 1 to 6 of 6
Thread: Camhead RT Mirrors
    Camhead RT Mirrors
    Ok, I read somewhere there's a new step to removing the mirrors (housing and all) on a Camhead (2010-on) R1200RT but can't find it here searching.
    Could some kind soul post the secret? TIA
    PS: Just got this bike and I WILL get a Reprom.
    100,000+ miler 32232's Avatar
    Southwestern Ontario
    Push on the outer, lower corner of the mirror glass, tilting it as far as it will go. Use a flashlight and look in the gap at the upper, inner corner of the mirror. Remove the Torx head machine screw and the entire mirror housing slides off to the front.
    It's explained on page 132-133 of my 2011 owner's manual for changing the front turn signal bulb.
    Dave
    '06 Triumph Scrambler (Trans-Labrador veteran)
    Thanks a lot, this does just what I need. Hadn't gotten that far in owners manual yet.
    To add some additional info for those searching: there's a hole in the bottom of the mirror housing to allow access to the keeper screw that holds the mirror itself into the housing. From there you have better access to the innards of the whole assembly.
    2011 R1200RT ka5ysy's Avatar
    Oct 2006
    Prairieville, Louisiana
    I agree that it is much easier to remove the mirror first with the setscrew, then access the whole housing.
    MSF #127350, Instructor, Louisiana Dept of Public Safety
    Motorcycle Safety, Awareness & Operator Training Program
    NAUI Instructor #36288, Board Member, Divers Alert Network
    Yes, it was the setscrew thing that I'd read about somewhere else and assumed was what I needed immediately to know, as on my previous '08 RT the mirror housing had to come off to allow access to the screws to remove the painted plastic mirror fairing.
    Clearly I was looking for access to the parking lights (could have been turn signal bulbs).
    Dave's tip--which I'm embarassed to say was in my new owners manual--did the trick.
    I ordered my RepRom this morning. Thanks again to everyone.
