Results 1 to 12 of 12
Thread: clanking on cold start
    poosu
    Mar 2011
    Port Orange, Fl
    In the past month my 1999 R1100RS has started a soft but very noticable clanking on cold starts which goes away in about 30 seconds. The colder the louder and longer it lasts, but it's never more than maybe 45 seconds. It seems like once the oil gets flowing all is well and stays good the rest of the day. Here in florida it never gets below 40 in the garage so it's not really cold. I tried a search but didn't find anything.
    poosu
    All-round Motorcyclist MarkM's Avatar
    Dec 2010
    St. Louis
    The 30 second part is similar to what the factory original timing chain tensioner sound does. Have you upgraded the tensioner?
    Here is the upgrade part and a little info about it.
    http://rubberchickenracinggarage.com/chain.html
    http://www.mklsportster.com/Articles/mcncct.pdf
    Mark M, St. Louis, '13 R1200GS
    Florida & Massachusetts
    +1
    What oil do you use?
    Vancouver, B.C. Canada
    Excellent step by step replacement guide here: http://advwisdom.hogranch.com/Wisdom...ionerSwap.html
    To check if you have the upgraded Tensioner is simple. If the bolt head on it is 15mm it's a new one. If it's the original one the bolt head is 17mm. Measuring it with an open end wrench is quick and easy.
    poosu
    Mar 2011
    Port Orange, Fl
    I currently am using Castrol 20-50 full synthetic oil. I was unaware of the timing chain tenisioner issue and am almost certain I do not have the replacement. I bought the bike used in 2006 with 10,000 miles on it. The previous owner said nothing about upgrading the tensioner. I'll get one on order. Thanks for your help
    Quote Originally Posted by poosu View Post
    You might think of trying Mobil 1 10W40 for the winter.
    You might think of trying Mobil 1 10W40 for he winter.
    winter in FL is not really winter, and 40 degs F is still a solid 20 degs above the minimum recommended usage temp for 20W50. do day temps go above ~70? if so, 10W40 is too light.
    poosu
    Mar 2011
    Port Orange, Fl
    Obviously I missed the timing chain tensioner upgrade. Are there any other upgrades I should know about?
    Have you checked to see if you have the old tensioner yet? It would be wise to do so before you go ahead and order one. (Post #4)
    poosu
    Mar 2011
    Port Orange, Fl
    Just checked and my tensioner bolt is a 17 mm so I have ordered the upgrade.
    Registered User upright's Avatar
    Feb 2012
    Overland Park, KS
    I had the same issue and the kit from Rubber Chicken racing solved the problem. Good luck!
    1999 K1200LT
    2000 R1100RT
    1998 HD Road King Classic (gone but not forgotten)
    Bruce Toner
    Feb 2013
    Barrie Ontario
    poosu
    I to had the awful clanking on startup. Replaced the left side cam chain tensioner with the upgraded tensioner from BMW and wow! What a difference! Starts are completely rattle free. Not sure if it is my imagination or not but I'm almost positive the bike starts and runs better.
    Cheers!
    Bruce
