Results 1 to 4 of 4
Thread: BMW Nav III wiring help
    Jun 2006
    A buddy bought a used Navigator III, with the power cable cut off flush at the battery end. There are three wires inside the black cable: red and black are obvious. Where does the purple wire connect?
    Dave Swift
    Grass Valley, CA
    '14 R1200GS, '07 R1200RT
    http://www.davidrswift.com
    Dec 2010
    Boston
    it might plug into something hot
    Central Ohio
    So you don't give up before somebody more knowledgeable comes along with details, I can tell you that third wire is used for a speedometer input. On BMWs there is a three wire connector near the fork - a matching plug is available as a repair part. I think I've seen the part number, pin outs and wire colors mentioned here before, try a search.
    Larry
    2006 R1200RT
    Jun 2006
    Quote Originally Posted by lkraus View Post
    I guess it would work fine hooking up just the red and black???
    Dave Swift
    Grass Valley, CA
