Exhaust Pipe Heat Tape
bobr9
143439
99 R1100RT
Looking for input on the use of exhaust pipe heat tape to shield the fairing parts from excessive heat. Does it result in accelerated degradation of the pipes due to trapped moisture, etc., or is it generally considered to be a prudent thing to do? Thanks.
I don't really know but if the heat stays in the pipes I guess that would mean the catalytic converter and O2 sensor would be hotter.
On my rt I don't think I've got any heat problem as long as I don't let it sit, idling.
Are you seeing the effect of heat on the fairing parts due to congested traffic riding in Georgia. Because other than stationary warmup of the engine (not needed, ever) or of the bike is moving slowly in congested traffic and high temps, there should no heat issues on the body parts if the bike is kept moving.
Actually, not sure as I bought the bike a year ago from a guy in the Chicago area, and the fairing damage was already there. I typically do not see much stop and go type driving, so maybe I will be all right going forward.
I'd bet a dollar to a doughnut that your visible damage was done by the previous owner idling the bike to warm it.
Ken
That's my guess. There are still riders out there who feel they have to "warm up" the bike before it's ready to ride.
That may have been the case on a 78 Honda CB750, or a mid-80's KZ-whatever, but not the case with any oilhead or later motor from BMW. I never even start my bike until I am sitting on it ready to ride, in temps from 17 degrees to 102 degrees. I start it, bring up the side stand, click it into gear, if no warning lights are on, go. Within a half mile I click off the cold-start lever and all has been good this way for the last 19 years with my RS.
Some years ago, I had two MSF students ask of they could start their personal bikes to warm them up before lunch. I said, "we still have a 15 minute exercise coming up, and doing that just harms the engine." They felt it had to be done so they started them and I ran the exercise, keeping an eye on the bikes. Not smart and not needed.
There are a host of heat reflective adhesive tape products out there. http://www.summitracing.com/search/part-type/heat-tape
I have some similar stuff on my RT oilpan tupperware where some slight brown blisters were appearing on the inside. Nipped it in the bud and no further problems. This is an easy preventative measure if you are concerned about heat damage going forward but as stated previously a moving oilhead normally will not blister.
