Results 1 to 12 of 12
Thread: K75 Reynolds hitch
    Jan 2013
    K75 Reynolds hitch
    I have a 1994 K75RT and just recently acquired a Reynolds trailer hitch for it. Does anyone have installation instructions for the hitch?
    I need to know specifically how it mounts and also how to hook up the wiring. Is there some sort of adapter to hook up the electrical connection to a USA spec trailer?
    Any help is appreciated!
    Maryland
    I may have the installation instructions for a K100LT. They are probably similar if not the same. I will look for it tomorrow. As far as the wiring goes, you can go to your local autoparts store and get what you need. What you need is a four wire to three wire converter. The bike has the following four wires (not including ground).
    1. Left turn
    2. Right turn
    3. Brake light
    4. Running lights
    Your trailer probably has the following.
    1. Left turn/brake
    2. Right turn/brake
    3. Running lights
    I ordered my converter online. I can look up the part number if you want me to.
    2004 R1150RT 151,500 miles , 1991 K100LT 128,000 miles, 1982 R100RT 106,900 miles
    Total 386,400 BMW miles
    AMA,BMWRA,BMWMOA
    Apr 2005
    Rapid City South Dakota
    If It has original wireing, It has a set of minirelays in the tube. It would be a wonder It they were still there and if they still worked. Original would have a 5 pin out plug That assumed your trailer had seperate turn signals from the brake light. There would then be 5 wires in plus a 12 volt input to power the relays. My advice would be to tear it all out and build your own wiring to fit your trailer. Harold In Kansas
    Harold In Kansas
    1985 K100RT Bullit
    1985 K100XX/EML Bemel
    Maryland
    I had forgotten about the mini-relays inside of the tube. I bought my hitch new way back in 91. It came with the mini-relays inside a piece of pvc pipe that was then inserted inside of the trailer hitch. It wasn't too long after I bought the hitch that the mini-relays failed. I suspect that the vibration from the four cylinder K100LT was the primary cause. I contacted Reynolds about this and was sent a redesigned board that eliminated the mini-relays and replaced them with solid state components. That worked for a while but also failed. I eventually just replaced it with a automotive powered trailer light converter.
    AMA,BMWRA,BMWMOA
    Maryland
    I believe this is what I used for a converter.
    http://www.thehitchstore.com/3-to-2-...ed-p-1709.html
    AMA,BMWRA,BMWMOA
    Maryland
    I found the following instructions for a Reynolds R-740 trailer hitch to be mounted on a K100.
    AMA,BMWRA,BMWMOA
    Maryland
    Here are the last two pages.
    AMA,BMWRA,BMWMOA
    Oct 2008
    Laurel, MD
    Quote Originally Posted by kioolt View Post
    THANK YOU!!!
    I have been searching for a year for these instructions.
    1994 K75/2
    Owner/Designer, LampOneDesigns.com
    Registered User spencer14554's Avatar
    Jun 2009
    Nesbit, MS
    Lightbulb Thank you!
    Thanks for posting these instructions for the Reynolds 740 Hitch. Definitely saved my installation as I just could not quite see the arrangement of all the pieces.
    Spencer
    Registered User giom's Avatar
    Nov 2014
    Halifax, NS
    Thanks - and additional questions ...
    I would like to add my thanks also - I have been searching (un-successfully) for a hitch for my K75s and come to some conclusions :
    1. I'm not the only one looking for a hitch (yet another testimony to both the appeal and longevity of the K bikes!)
    2. The only option I could find (here in north America at least) was beyond my budget ($425 US + taxes/shipping etc)
    3. The Reynolds R-740 keeps coming up in searches and seems to have been a great hitch - I particularly like the "single-sided" design as I have read this allows for removal of the rear-wheel without removing the hitch - something we all need to do regularly for spline lube etc
    So,
    Unless my search comes up with a used option (please contact me if you have one) I'm thinking I may have to fabricate one from this information and/or measurements taken from the bike. In addition to the above info (thanks again) I found a link to a 1985 brochure which shows the hitch fitted to the RHS foot-peg plate and makes reference to the 3 other mounting points.
    Does anyone have any drawings of the actual hitch (and associated mounting hardware) which might add to this info?
    Any other experience / information on the Reynolds hitch would also be much appreciated.
    Cheers,
    Gio
    1994 K75s (UK spec) w ABS, low seat option - since 2006
    2000 MG V11 Sport (in original green) - since new
    1984 Honda 200 ES "Big Red" - farm vehicle
    RK Ryder
    London, Ontario
    Quote Originally Posted by giom View Post
    Cheers,
    Gio
    After reading your post, I went to the garage and took this photo. Is this a Reynolds Hitch, that Harold in Kansas sold me a three years ago? If so, I might be able to answer some of your questions.K Bike Hitch.jpg
    Paul
    Knights of the Roundel #333
    Nov 2014
    Halifax, NS
    I think it may well be ... put me in touch with Harold from Kansas ..!
    Seriously Paul - if you could post up some pics of the mounting points that would be very much appreciated.
    What kind of hitching system is that - I don't see a ball so presumably the pin type?
    Gio
