Results 1 to 5 of 5
Thread: 1991 K75RT start
    Mar 2008
    Belton Tx
    1991 K75RT start
    Quite I often I have to pull in the clutch lever in order for the starter to operate. This is with the transmission in neutral. the N light on and the gear indicator showing "0". Is there another safety switch?
    Ron
    91 K75RT ABS
    3 Red Bricks
    Jan 2007
    Pleasanton, Ca.
    There is no other safety switch.
    It sounds like pin #5 on the back of the instrument cluster is not making good contact. There also appears to be a diode on that wire inside the cluster between that connector and the neutral light. That might be causing the problem, but my guess is the connector.
    LONG MAY YOUR BRICK FLY!
    Lee Fulton Forum Moderator
    3 Marakesh Red K75Ss
    Mine, Hers, Spare
    Registered User WalterK75's Avatar
    Feb 2009
    Mississauga, Ontario
    Is the side stand up when this happens?
    Walter
    All government, of course, is against liberty.
    H. L. Mencken
    Mar 2008
    Belton Tx
    There is no sidestand switch on a K75.
    Ron
    91 K75RT ABS
    3 Red Bricks
    Jan 2007
    Pleasanton, Ca.
    There is no side stand switch on K75s. They use the auto retract side stand that is operated by the clutch lever to insure you don't drive off with the side stand down as opposed to a kill switch on the side stand.
    Walter, based on your forum name, I assume you own a K75. Go out and check it out. No switch. Side stand doesn't matter for starting, just neutral or clutch in.
    Mine, Hers, Spare
