Results 1 to 15 of 16
Thread: Snowflake wheel recall still available?
    I've got a front wheel that fits the recall. Just wondering if it's still possible to get a new rim. Haven't called the dealer yet and try to explain to them a old recall. The local dealer, Milwaukee BMW was recently sold to a car dealership and from past experience, they may not have a clue as to what I'm talking about. Searched here and on the net a didn't find much info.
    Thanks, Ed
    It's still ongoing...here's details:
    http://bmwmotorcycletech.info/19inchrecall.htm
    Thanks, I saw Snowbum's page on the recall. I guess I didn't find any "official" info. I'll give the dealer a call tomorrow an see what they say. I couldn't believe I had one and that they are still around after all these years.
    Registered User PAS's Avatar
    Jun 2011
    N.E. Ohio
    Here you go, not sure how you can print from here.
    Generally, you will likely have to bring the bike in with the wheel so the dealer can verify that the bike has not had a recall against it already. If you came upon a wheel through a used source that didn't come with the bike, I think it will be very difficult, if not impossible, to get the wheel accepted as part of the recall.
    Feb 2005
    Trinity, NC
    As Kurt says, the recall is tied to the VIN. If your bike VIN has already had the wheel recalled you are out of luck. The recalled rims are supposed to be destroyed. If you get a replacement rim be aware that the hub/bearings are supposed to be properly greased and set up. They often are not. Especially if the service techs at your auto/moto dealership aren't familiar setting up snowflake wheel bearings.
    Michael Stock, Trinity, NC
    R1100RT, R100, R60/6
    Registered User paulj's Avatar
    Sep 2004
    Prairie Grove, Arkansas
    mandatory for 10 years
    Much speculation on this topic, and so many conflicting 'authoritative' answers that it seemed a good idea to check with the source.
    http://www-odi.nhtsa.dot.gov/recalls/recallprocess.cfm
    A recall is in effect for ten years from original retail sale date. This however does not mean that the manufacturer will deny claims, only that they are no longer obligated.
    Paul
    My understanding of this recall, probably explained by Snowbum, is that is a lifetime recall...it will never expire. Maybe that means until a certain percentage of the produced wheels are destroyed...or until the number of recall requests fall below a certain number per year...I don't know if there are any limitations. BMW called this on themselves...it was not forced on them. But in the end, it has taken up what appears to be a mandatory recall which will run for a long time.
    Maryland
    Quote Originally Posted by soldemall View Post
    I believe you have misinterpreted what you read.
    From the link above " For example, if a defect is found in 2003 and a recall ordered, manufacturers are required to make the correction available at no charge only for vehicles purchased new in 1994 through 2003." To me that means if the 1993 model had the same safety issue, a recall would not be required. It not saying there is a 10 year limit on recalls.
    2004 R1150RT 169,000 miles , 1991 K100LT 128,700 miles, 1982 R100RT 106,900 miles
    Total 404,600 BMW miles
    AMA,BMWRA,BMWMOA
    Further info on these wheels?
    Can anyone upload (or private message me for my email) clear hi-res pics of BOTH wheels - the defective one, and the replacement one?
    And clearly show what the visible differences are? I have seen a few pics, but they are so bad and poorly descriptive that I am not sure what to look for to see if a wheel is one of the recalled ones or not!
    Thanks,
    The differences are pretty clear in the pictures on this website:
    Similar pictures here:
    http://robfrankham.co.uk/bike/dreade...eel_recall.htm
    Finally called the local dealer and they said to bring in the wheel to confirm the casting numbers on it and I should be good to go. I'll keep this updated as I go through the process.
    Jun 2011
    N.E. Ohio
    Make sure you see them grease the wheel bearings. They arent greased.
    rsbeemer 22600's Avatar
    Jan 2011
    New Braunfels,Texas/Taichung, Taiwan
    I had mine replaced in 1998 on my 1980 r100rs euro mdl. I was at the Missoula Mt. ralley and this guy named Bob Henig came along and pointed it out to me. The wheel had no cracks but I had it changed out as soon as I got back to Texas.
    DW
    Sep 2004
    Arlington, TX
    Recall wheel
    Just so you know.
    It seems that BMW was not very carefull about disposing of these recalled wheels. Although my first guess is that there were some unscrupulous dealers that didn't destroy them and later sold them to unsuspecting customers as used wheels!
    I say this because BMW has actually replaced more recall wheels, than they actually produced! Well, when they figured this out, they adopted the policy of checking VIN numbers.
    The last recall wheel that I had, I had to show them the bike, with the wheel attached. I also had to prove to them that the bike was currently registered, insured, and drivable. Really can't blame them for that, at this point in time.
    Boxerbruce
