Results 1 to 7 of 7
Thread: 2007 R12R - Canisterectomy and Tank vent fault codes
    Jul 2007
    Bowie, MD
    As part of my new shock installation I pulled the canister and jumpered the tank vent to the hose that goes down to the left foot peg. I hooked up the GS-911 and checked for fault codes, all is well. Now I'd like to pull the tank vent switch as it looks ugly and has no function with the canister removed. So I then disconnect the electrical connector that goes to the tank vent switch and check the fault codes again. Now I get a fault code for the tank vent switch. I hook it back up and the fault clears. OK, the engine runs great with the switch electrically disconnected. Should I care if I have a fault code for the vent switch?, ie would this fault then set a chain of events further down the Motronic stream or can I ignore this?
    Ignore it at your own PERIL
    The Charcoal Canister Police will detect the fault code when they pass you on the highway or from the DRONE that is flying overhead as we speak and take your Birthday AWAY .
    Jul 2007
    Bowie, MD
    Great, I'm already in trouble with the mattress police for removing the tag.....
    My only concern is having the fault effect engine management functionality. I can't imagine why it would but this is a BMW.
    Canister code
    Quote Originally Posted by fletchdude View Post
    I normally tape the connector up so no water or dirt can get at it and strap it out of the way and leave on. It has not been a issue on the past five bikes that I have removed the canister from.
    And yes they found me and I no longer have a birthday.
    Dave
    Spring Lake NJ, USA
    Ummm... Jim, why not just leave the valve in and connected electrically (like mine is..)? It really doesn't weigh enough to give a performance edge by removing it, and the current draw on it is in the microamp range.
    Engineers sometimes overthink things.
    Jul 2007
    Bowie, MD
    Thanks Dave.
    When I was researching this topic someone had posted "no issues disconnecting the switch and confirmed by the GS-911". So when I got a fault code my first thought was, well does this really mean anything outside of no reply from the switch now that its disconnected? If you think about this a bit more, its really whats missing: there are no engine fault codes as in everything else but the switch are just fine. Since you have had your switches out for years with no problems that seals the deal. Thanks a bunch!
    Don, yes I could leave the switch in but its really nasty outside and I can't ride my bike so I keep wandering in the garage poking at stuff. The bike design is really clean and then there is this ugly switch. Maybe I should have gone to medical school instead of engineering. I seem to be pulled towards surgery (now "switchectomy")
    Fletch
    BinkleyLane binkleylane's Avatar
    Jul 2012
    Springboro, OH
    Lightbulb Idea
    Fletch,
    Why not leave it connected and move the switch to some concealed location. No seeum/No Fault code.
    B-est M-otorcycle (in the) W-orld
    Have Bike - Will Ride
