Results 1 to 13 of 13
Thread: K12gt 04 with a challenging shift lever ergonomics
    TAC302
    I recently picked up a beautiful bike but I seem to be challenged by the spacing between the peg and the shifter. My size 12 foot is having trouble fitting in to operate the shifter. It doesn't seem to have any adjustment available. Has anyone else had this issue and what are my options to fix this?
    Tom
    Jan 2009
    Hillsborough NC
    The lever has adjustment where it attaches to the linkage. It can be rotated about 30 degrees forward or back. If you need more you can remove it and grind off a bit more of the stop that allows it to rotate only so far. The other part of the linkage can be adjusted but that requires disassembly inorder to move things just a little.
    You might also try moving your pegs up and back to the alternate position which will give more room as well. It is the position that once accustomed to, I prefer.
    I know that mine used to drag a bit. When the bike was apart for clutch/alternator repair (frame lifted off of motor) it was altered so the angle changed. It makes it a bit higher so you have to focus on shifts a little more. I think this was accomplished by adjusting the arm on the shifting shaft coming out of the transmission. I like it better the other way but this way it is a bit more out of the way.
    Hope this helps you some.
    Nice looking GT.
    Let us know how you work this out.
    NCS
    03 K 1200RS (Black is Best)
    03 Honda RC51
    74 Honda CB750 K4
    Debbie's Servant Lee's Avatar
    SW Iowa
    Can you take a closer picture of the shifter? To me it looks like the shifter may be angled back.
    On our K1200RSs the shifter was angled straight down. I'm talking about the part that touches your boot.
    This pic shows the position I'm talking about.
    Lee
    2016 R1200RS
    MOA # 30878
    Jun 2007
    I am a size 12 as well and have no problem. So, what Lee is referring to, and I agree with him, is that your shifter appears to be adjusted to the back position which is intended to be used when the pegs are moved to the upper position. It is pretty much designed such that the more rearward ( anticlockwise) rotation of the shifter is for the upper peg position and the more forward rotation is for the lower peg position. I believe it is also intended for the ball of the foot to be on the peg, so if your instep is on the peg, it will be quite tight. Then again, if you wear large style boots on your size 12 foot, that will not necessarily go with the K12 design. My stepson wears 10s, but was unable to get his big engineer/logging boots to fit in the space with the limited ankle flex he had. To check shifter adjustment, back out the cap screw in the lever attachment point. Pull it all the way out to observe the two settings possible, then adjust to the more forward position, clockwise rotation. It would be nice if BMW had just made each side with a full face of ridges that mesh so you could choose exactly what you want, but, that decision was made 15 years ago.....
    Jim Douglas '00 K1200RS >136,000 miles my primary bike again,
    '06 Kaw 650R track bike sold
    http://www.seagullbb.com/
    Jan 2009
    Hillsborough NC
    modified earlier post and attached picture.
    I also have some logger and engineer boots and they will work on the bike (size 10) but the thicker toe and sole just makes it feel a bit strained. Their design and the design of the bike just don't match so well. I also have some Sidi Crossfires that do work as good boots on the bike. They are a bit stiffer and thicker in the toe than say my Sidi Vortice or Alpinestar SMX boots but still work OK. I have some crossover boots, Gaerne Explorer boots that work great with the set up as well. So do play around with this simple adjustment, grind off a little more to gain a tad more room and see if that satisfies your needs.
    NCS
    03 Honda RC51
    74 Honda CB750 K4
    Jul 2007
    New Jersey
    Hey NCSteven
    I came here today because I purchased an 03 K1200RS about an hour ago. It looks like the shifter and the footpeg were draggin a little at some point
    I hope you were getting your full enjoyment out of the K and those ground down pegs aren't an indicator of a former ambulance ride.
    Jun 2007
    Oh, he has a point there.....though the end of that peg looks like it was snaaaaped off from maybe a garage tip? I had one break at the hinge point, but on the 2000 models, there is the one inch rise before it goes horizontal. Easy replacement though. Good drawing on the pic for a more detailed description.
    Jan 2009
    Hillsborough NC
    They were worn down from having loads of fun. I had considered mounting the earlier higher pegs but never found any at a cheap price and then they would require changing the shift lever.
    NCS
    Turn 4 VIR, at CLASS
    03 Honda RC51
    74 Honda CB750 K4
    TAC302
    Thanks for the thoughts
    Many good thoughts here.
    I'd move the pegs up but I moved from a '95 K11rs to the gt and one of the reason was to have a more upright and less crunched position. Having taken the end of the linkage off, I do not think my setup is adjustable more without grinding. I also believe that the whole thing might be a bit bent in as well. Maybe some heat and a gentle pull and I can fix that. I have resolved to just use a pair of boots more flexible and thinner at the toe though the end of the shifter still seems to fall too far up on my foot. I'm sure I can learn to live with it given that I absolutely love everything else about the bike.
    Dec 2005
    Austin, Minn
    Shift peg fix
    This question seems to come up a number of times.
    I had the same problem. I wanted an upright riding position
    and did not want my foot angled down so much.
    Also, if the shift lever isn't completely released,
    you can not shift to the next gear.
    Which is what happens with a big boot.
    I removed the lowest piece of the shift lever,
    the toe piece which is ground off in the picture above, and put
    a long bolt directly into the mounting whole for that toe piece.
    I put on the bolt several plastic spacers to make a larger
    diameter and to allow the bolt to be tightened.
    The spacers I used I found at a hardware store. They were about
    a inch long and 1/2 or 3/8 inches in diameter with a 1/4 inch hole
    through them.
    I used several and then adjusted the final length with
    metal washers.
    The one closest to the mounting threads needs to be
    ground off at about a 45 degree angle, same as the mounting
    surface where the thread is.
    No adjustment is needed, or can be done .
    Use a bit of loctite to make sure it stays.
    Sorry, I don't have a picture.
    Phil
    2004 K1200GT II 2013 K1300S 2004 K1200GT
    1996 K1100RS 2005 R1200GS 2000 K1200RS
    1995 K75S 2009 HD Road King plus others
    Quote Originally Posted by bird302 View Post
    Bird,
    Nice looking bike. Would you have a better picture of that rear rack. I think my wife
    would like that on her '03 GT.
    It looks a little larger than the BMW she has on hers now. The same as the one in post #3.
    edit: upon further review (and a closer look) it appears to be some type of GIVI (I see GIVI brackets).
    edit2.0: no I take it back, it's not a GIVI rear rack. My original question is still valid.
    TAC302
    Tail bag
    The bag has a BMW logo on it so I think it is a bag sold thru a dealer. I don't really like it but it works great for holding the laptop when I want to ride to work. It also locks to the rear rack so I guess that is good but cant be locked at the top being a textile unit. You wanted to know about the rack though and it appears to be a stock piece. The bag is not that big and has a frame and locking mechanism to it. I will post a pix ASAP.
    Registered User jgr451's Avatar
    Jul 2003
    Left Coast Canada
    Ah:The fast colour I see!Good pick.
    Sometimes,nothing is a real cool hand.
