Results 1 to 4 of 4
Thread: Bleed ABS Modulator on 2005 1200 GS
    Nov 2006
    Putting in rebuilt ABS pressure modulator..With the 5 bleed nipples on the Modulator and the need to bleed them in order etc. I'm thinking that it might be a good idea to put speed bleeders on it??? Any thoughts appreciated..
    Pat
    Cam Killer marchyman's Avatar
    Jun 2008
    SF Bay Area
    Don't you mean 6?
    I guess speed bleeders would make the job a bit easier. I've never bothered with speed bleeders, but I do have a motion pro one-way valve in my bleed line. You can just see it behind the wrench in this image.
    Nov 2006
    looks neat ...that will do it thanks...I went on their site and they have diff. sizes..I am away from home for a while...you have the part number or size... Thanks Pat
    Dee G flymymbz's Avatar
    Nov 2006
    Central WA
    My first experience with the brake bleed on my 04 R12C left me wanting to push the bike in front of a fast moving freight train. I got the Speedbleeders for the ABS unit and the bleed nipples on the calipers and the funnel tool from Beemer Boneyard.
    http://www.beemerboneyard.com/abs3funnel.html
    Don't let the fluid level drop too low or you'll have to have to reset the error codes. GS 911 tool makes quick work of that, and it will also cycle the ABS unit and push the old fluid out and bring the clean stuff in.
    A bit spendy to swap every thing over, but it makes things so much easier.
    Too damn many bikes to list
