Page 2 of 2 FirstFirst 1 2
Results 16 to 17 of 17
Thread: Can i double up the bar risers? 2012 R1200RT
  1. #16
    Because of the arm
    Quote Originally Posted by Ponch1 View Post
    Why would it be less? Does he lose leverage or gain it? The thing about all vehicles is that they are made to work well with a range of human dimensions. If a rider or driver is on the ends of the bell curve, it just doesn't work as well or at all given a particular vehicle. From my observation, the RT was made for someone 5-10 to 6-00 tall with a 32-34" inseam and weighs 150-180 lbs. Fall outside of that and it gets uncomfortable.
    Expanding this a little...
    Let us just imagine that the handlebars are 5 feet back and connected to the forks with an arm or lever. Now how much movement do the handlebars need to achieve a given amount of front fork mvmnt? The same as if they are directly above the forks?
    Btw, i DO think yur correct about the RT design.
    2012 R1200RT, 2004 Vespa GTi, 2001 Kawasaki 220R, 1981 Vespa P200E, 2004 BMW 325i
  2. #17
    Ponch ponch1's Avatar
    Dec 2010
    Fountain Hills AZ
    Quote Originally Posted by mule View Post
    Measure the arc of movement in length or distance. shorter arcs may imply greater response, but also require higher effort.
    My Motorrad
    BMWMOA 162849 | BMWRA 41335 | VROC 8109-R | VBA 19
