Results 1 to 9 of 9
Thread: Bar set backs or replacement bars for late ('93) R100RS
    42968
    Hi all,
    I'm looking for specifics on what handle bar set backs work with this model. Over the past couple years, I've found my hands getting numb after awhile and I think I'll solve the problem if I can install some bar backs that fit the bike.
    If anyone has a brand/model that fits this bike, please let me know what it is and where I can get them. I'd also be interested in replacement handlebars, but again, I'd like to get very specific make/model bars to fit this bike. Thanks much!
    Jeff
    Albuquerque, NM
    Well then, you need an RT, don't you?
    No, not really.
    I rode an R100RS in stock configuration for 28 years and have had several opportunities to ride RTs and guess what? My hands and wrists hurt the same.
    I think it's more a matter of not gripping so tight and frequently removing hands from grips to flex them. Nice to have a "cruise control," then. Luckily on Airheads you can fit the throttle screw. I've electronic cruise on 1200RT and on my 1100S I use an o-ring.
    Kent Christensen
    21482
    Beemerphan Radar41's Avatar
    May 2003
    Longmont, CO
    Cool Barbacks
    Quote Originally Posted by 42968 View Post
    Hi all,
    Jeff
    Jeff,
    Look at these:! http://m.motorcycle-superstore.com/2...-1-8-Bars.aspx
    Also some of us have installed the K75S bars with some success. I'm a 6'+ and the K75 bars worked for me.
    Don "Radar" Wreyford
    00 K1200LT, 98 R1100GS AE, 84 R100RS, 76 R75/6
    MOA # 91738, RA #27032 , ABC #7915 - "Insanity is doing the same thing over and over again, but expecting different results" - Albert Einstein
    Apr 2012
    Gilbert, AZ
    Don, when you put the K75 bars on did you have to use longer cables? I've been thinking about doing that to my RS.
    2004 R1150RT
    BMW MOA 181289
    May 2003
    Longmont, CO
    Cool K75 bars
    Quote Originally Posted by MARKAZ View Post
    No, on mine I was able to use the same cables. I can send photo's if you like.
    Ordered the bars from Ted Porter, don't know if he still has them, no boubt there are other sources.
    Registered User boxerkuh's Avatar
    Carolina's
    Bob's BMW sell bar backs, as well as other BMW dealers. They do become available on "flea bay" too. My suggestion is that you sit on the bike and put your arms where they feel good to you. This may be back, it maybe up or both. Handlebars do make a difference as well. I dislike the RS bars, I could never get comfortable with them. I ended up installing a set of "S" bars. S bars are available new from Flanders in CA and are available in chrome or black and in different shapes (pull back and width). K-RS bars are used by some, I did not like them. I did build a custom riser one time just to raise the bars and that worked well. There are multiple choices and combinations that you can try, without changing the length of the cables. Have fun figuring out what works for you.
    Keep the rubber side down!!
    1986 R 80 RS
    1992 R 100 R
    BMW MOA Life member; Ironbutt Member; Airhead Member
    May 2003
    Longmont, CO
    Cool Barbacks
    I used a set of these on my GS, to be a bit more comfortable when standing ( being 6'+ ).
    http://www.motorcycle-superstore.com...-1-8-Bars.aspx
    They might work on the RS as well .
    Mar 2008
    DeLand Florida
    I installed K75S bars on two of my bikes, and another set on a friends RS. I was able to use the stock cables each time, but you do have to reroute the throttle cable a bit because it will cause the engine to rev up a bit in a full left lock. Thankfully this never happens when you are riding though, just when you are moving the bike around in the garage.
    Wayne
    Jun 2009
    Ft Atkinson Wisc
    figuring pull back
    If you go to www.cycle-ergo.com you can select your bike, add in you height and inseam. they will show your forward lean and knee angles. In the customization section you can adjust rise and pull back and it will show how it changes your posture on the bike. This will give you an idea what you will need to achieve the position you want. frank
