Results 1 to 4 of 4
Thread: '82 R100RS Camshaft Question
    Left Coast Rider
    Is it typical for the cam to appear offset to the tappets? I've disassembled to the engine case and it looks like only half the cam lobe contacts the tappet. Cam and tappets appear in fine condition.
    Thanks in advance for your input.
    jimmy armour
    Jul 2009
    Lucknow ontario canada
    cam off set
    hi, there is some off set to cause the cam followers to rotate for various reasons ,hope this helps ,good luck ,jimmy
    May 2012
    VA
    Yes. The airhead engine uses 'flat tappets' like many other engines. The base of the tappet is not actually flat but is slightly concave. Similarly, the cam lobes are not flat but have a slight taper. The combination allows the tappets to rotate and draw oil in between the tappet and cam.
    If you would like to learn more or just have a healthy skepticism, Google search using the key words 'flat tappet cam design' and a wealth of information will be provided. Also, each tappet should be returned to the respective lobe when replaced. Otherwise, it is considered best to replace or regrind the tappets and break-in the camshaft again.
    Stan
    AH# 13238
    Left Coast Rider
    Thanks folks!
