Results 1 to 14 of 14
Thread: Recall: Transport Canada / BMW [2013] R1200GS
Hybrid View
    Still Wondering mika's Avatar
    Aug 2004
    Fly Over Land
    Transport Canada: BMW issued recall on R1200GS [2013]
    On certain motorcycles, transmission oil pressure may be too high, causing the output shaft sealing ring to leak. Oil leakage ahead of the rear tire could render the vehicle unstable. This could result in a crash causing property damage and/or personal injury. Correction: Dealers will install an oil restrictor to reduce oil pressure at the transmssion output.
    Pass the mustard and UP THE REVOLUTION!
    St. Paul Pioneer Press , Minneapolis Star Tribune
    Lost again Texpaul's Avatar
    Oct 2006
    San Antonio, Tx
    You have to wonder how an issue like that ever got thru to the customer. Seems they would have encountered that during testing. They did test, didn't they
    Paul Mulhern
    MOA# 56330
    The biggest mistake people make... is thinking they have time.
    MOA #24991 Pauls1150's Avatar
    south of Los Angeles
    How does one regulate pressure in the tranny? Reduce the quantity of oil?
    And, is there an atmosphere vent? I'd expect a little bleed if there was too much inside.
    Quote Originally Posted by Texpaul View Post
    Testing? It's roughly the same transmission used on hexheads since 2005. The recall is not about the not-quite-released-yet liquid cooled bike. Also, the recall is limited to 31 bikes. That leads one to suspect that there was a specific manufacturing issue with those 31 bikes.
    Aug 2004
    Fly Over Land
    Correct. As I understand the recall it is the current model. I have searched US, UK, Australia, and EU - no recalls on their sites at this time. Maybe in the future but not at this time. Right now 31 units in one country.
    got, got, got no time... rguy's Avatar
    Aug 2003
    Rogersville, MO
    Defective breather? That is about all I could imagine would cause an overpressure problem like that. (Breather # 23007693739)
    Neal - '16 R1200GS / '09 R1200GS (for sale) / '81 R65
    _______________________
    Be the person that your dog thinks you are.
    Aug 2004
    Fly Over Land
    I have written BMW Motorrad CA asking for clarification. I will report what they say when I receive it.
    This applies to the NEW Wasserhead. Not to any model you can buy today. Inside source says this will be corrected before any bikes are sent to dealers in the US.
    It's a non-issue.
    Thought this was a major redesign of case...clutch relocated,output shaft flipped to port side? I was under impression this was the new set up being recalled.
    Steve Henson
    The new bike has an integrated transmission with a wet clutch at the front of the engine case. There is no separate transmission case. There is no separate transmission oil.
    Edit: It is also quite possible that the description of the problem bears no resemblance to the actual issue and it is the new bike that is being recalled.
