Results 1 to 9 of 9
Thread: ABS Light-06 R1200RT
    Innkeeper
    Lake Havasu, AZ
    Will be looking at a 06 R1200RT this upcoming weekend. The seller states that the ABS light stays on all the time.
    What could be the diagnosis and the cost to repair?
    rabid reader dbrick's Avatar
    Santa Cruz CA
    Lots of possibilities, ranging from easy (misadjustment of the gap beween an ABS sensor and the tone ring) to hard (failure of the electric motor within the ABS module, or clogging of the brake fluid filter screens within the module). With a module failure, the dealer will want to replace it at a parts cost of ~$2400. Module Masters in Idaho has repaired a number of these for far less money.
    David Brick
    Santa Cruz CA
    2007 R1200R
    moved over here to Hexheads...
    Another issue on some of the 05-06's was the front sensor wire rubbing/shorting on the rotor...there was a service bulletin and most fixed by dealers.
    Steve Henson
    Quote Originally Posted by INNKEEPER22 View Post
    Easy enough to diagnosis with computer code readings. Had the same issue recently on a long trip and the problem was a failed ABS modulator. The cost is significant at $2200 to replace. Would assume the worst and price accordingly before you buy.
    Jan 2013
    Boyd TX
    I'm not familiar with your bike, but my R11R was pretty easy to reset the ABS system. I would check and see if resetting the system was as easy on this RT. You could be in luck and it is an easy fix. If the ABS still failed it would make me a bit nervous unless I knew what code it was throwing. Just a thought.
    "Resetting the system" is not a fix. Fixing the problem is the fix.
    Jan 2013
    Boyd TX
    Yes I agree obviously. I guess I will have to be more specific. I bought my R11R used and the ABS lights indicated a fault. I reset the ABS and the fault went away. That was almost 15k miles ago. Same could happen here....maybe not but it is worth a shot IMO.
    On the Road
    Aug 2012
    Northern California
    resetting ABS
    how do I reset the ABS on my 2000 E1100RT?
    John
    On the Road
    Aug 2012
    Northern California
    resetting ABS
    Sorry I meant R1100RT. Typo
    John
