Results 1 to 2 of 2
Thread: Helmet fitting
    Nardowell nardowell's Avatar
    Normal, IL
    Helmet fitting
    My 2009 aria profile helmet fits just as it should according to the online videos. However, the cheek pads pushed in too much so I started to order the next size smaller even though they were $45.00 from Arai.
    When I got to the part about shipping cast, they wanted to charge $50.00 to ship them.
    After a glass of pino noir, I had enough courage to take the chin pads out and trim them down.
    Now they fit well and I saved enough for a case of pino noir.
    Moral of story----they are easy to trim.
    Nardowell
    Hoa Binh (Peace)
    Vietnam '69 and '70
    2012 R1200R classic
    Registered User jamesdavidhoward's Avatar
    Feb 2010
    Aloha, NW Oregon, Portland suburb
    Helmet fitting
    Keep in mind that many brands of helmet with removable cheek (and other) pads have pads that are pre-sliced part-way through to adjust their thickness. In my Arai, if one removes the fabric covering the cheekpad, there is a 5mm-thick pre-slice that can be separated. I'm assuming that - since the manufacturer pre-cut the slice - that the result is still fully protective as designed. Don't forget that is important!
    James D. "Jim" Howard jhoward@alumni.caltech.edu
