Results 1 to 13 of 13
Thread: Airhead Tire Pumps - Do they work?
    Jun 2007
    Minneapolis, MN
    Wondering if these pumps can actually be used to adding TP.
    My R60/5 didn't come with one.
    Should I have one?
    Ken Tuvman
    Excelsior, MN
    K75s, R65LS, R60/5
    Sep 2003
    Virginia Beach
    If it's the original one that came mounted on the frame (hand pump) - yes, they do work. I wore mine out pumping up VW tires. It should really be used on just motorcycle and bicycle tires. I've fixed a few flats on the road with the original spoons and hand pump quite a few times.
    Virginia Beach
    current:14 R1200RT 75 R60/6
    2 different questions.
    1) yes, they work.
    2) "having one" really depends upon your expectations and desires. if i had one, i might use it. if i did not, i would either purchase a small electric pump, or use CO2 cartridges, or buy a good bicycle tire pump (mntn bike spec rather than road spec). my choice of preferred weapon would probably be same as order listed.
    3) only thing that would make me want a stock hand pump would be if i was going for a concourse level restoration. and since the original steel one is NLA, even less reason to go for a new OEM, as they are plastic construction.
    Sep 2004
    Arlington, TX
    Tire pumps
    If you hold yout thumb ovrt the end, pump it, and you feel pressure, then yes, it will work.
    With that in mind, consider the fact that it takes about 3000 strokes to get enough air in the tube so you can get to the nearest compressor. Don't ask me how I know.
    So my opinion is that they're just there for looks, and I carry a small electric pump.
    Boxerbruce
    I have 3 pumps with me when I tour. The original pump clipped to the frame (just for show, I suppose). I also have a good bicycle pump in the saddlebag. I usually use this to top off my tires each day. I have a DC-powered pump that runs off the battery once I plug in the cigarette light female receptacle. I went to Wally World and bought one of the cheap $15 battery powered pumps and ripped away all the plastic and retained the essentials. I mounted that to a small piece of plywood just to hold it together. I carry the electric pump, the cables, and cigarette adapter in a small plastic pouch in my saddlebag.
    Jun 2007
    Minneapolis, MN
    Quote Originally Posted by 1074 View Post
    Thanks guys and I can surmise how you know, BoxerBruce!
    As always, thanks guys.
    I know Hucky's sells them and good to know that what he's selling may be plastic - I guess I'll ask when I place my parts order. It's not that I "need" one to use but would "like" to have on the bike as I've been cleaning, servicing, and putting her back together as I enjoy doing!
    Ken Tuvman
    Excelsior, MN
    K75s, R65LS, R60/5
    if you are having to top your tires off daily, you have leaking tubes that need replacing. unless you are going thru major changes in altitude (several thousand feet), you really should not be seeing big changes in your air pressure on a daily basis.
    Maybe I should have said "checking my tires". But sometimes, they might be a pound or so different...not every day though. Some of the trips are up and down elevations changes.
    Wear your gloves using the original pump. It gets pretty hot after 3000 strokes!
    Horizontally opposed Spaulding's Avatar
    Dec 2010
    Los Angeles, CA
    Quote Originally Posted by kentuvman View Post
    The ones that Hans sells (Hucky's) are metal and the one I received from him looks identical to the original that's in my R90S.
    Jun 2007
    Minneapolis, MN
    Quote Originally Posted by Spaulding View Post
    Thanks, placed a parts order with Hans today, including the pump!
    Ken Tuvman
    Excelsior, MN
    K75s, R65LS, R60/5
    When I bought my R90S in late '75, the old line dealer told me that with the /2 air pumps, 4 strokes=1psi. The /6 pumps were less. So, maybe not quite 3000 strokes.
    Nick Kennedy
    Telluride Colorado
    Yes they do work and they will work extra good, if you take a couple of minutes to take it apart, clean it and lubricate the shaft and the inside.
    Those airhead tires are skinny and don't hold ton of volume. I like mine just fine.
    Nick Kennedy
    1978 R 80/7
