Results 1 to 15 of 21
Thread: sourcing wire
    Dec 2008
    San Antonio, Texas
    sourcing wire
    I'm trying to find correct wire for replacing old/worn wires in a BMW wiring harness. Anyone happen to have a source for wire in the correct color codes and gauges?
    Registered User kentuvman's Avatar
    Jun 2007
    Minneapolis, MN
    I'd think of Motobins or Huckys spare parts for new wire or EBay, moa flea market or IBMWR for used a used wiring harness.
    Ken Tuvman
    Excelsior, MN
    K75s, R65LS, R60/5
    IBA #44567 Ken F's Avatar
    Sep 2009
    SW, MO
    If you are looking for a single wire of a certain color & guage, try a forign car salvage.
    BMW, Mercedes, Audi, Volkswagen.
    Ken F
    -Albert Eienstein
    Pismo Beach, CA
    If you're blessed with a /5 or older, you can buy an entire wiring harness (engine, main & subframe) for around $150. You need to be aware that the actual gauge of the wire is slightly smaller than the 40+ year old stuff. /6 and later.... not so good; $650+
    As mentioned, a fairly good source for "single" wires might be eBay; I frequently see wiring harnesses offered. The chances of the particular wire color you need being tact are probably pretty good.
    Lew Morris
    1973 R75/5 - original owner
    1963 Dnepr
    Dec 2008
    San Antonio, Texas
    I was specifically looking for the correct size and type, with correct color codes, I was going to roll my own.
    Pismo Beach, CA
    Just found this with google at BMW of Las Vegas > http://www.bmwoflasvegas.com/Bikers-...ductId=9180354
    Lew Morris
    1963 Dnepr
    Albuquerque, NM
    Given the colors offerred by Las Vegas I'd conclude it's not really oem wire.
    Good to remember that OE wire is not "gauge" sized but rather sized in millimeter cross section.
    Kent Christensen
    21482
    Pismo Beach, CA
    +1 What Kent said.
    I don't know who is making the "new" harnesses. The one I bought came from Bob's BMW and the diameter of the conductors is smaller than those in original harness.
    edit - I didn't spend any time looking at those wire colors when I posted that. Most are not BMW related colors, others are not present at all (blue/red, red/green, etc.)
    Lew Morris
    1963 Dnepr
    Dec 2008
    San Antonio, Texas
    to clarify, it doesn't have to be an -exact- match.
    It needs to be of equal thickness, or greater.
    It needs to have the same color patterns, but not the same shade. so long as it's 'blue with a red stripe' the colors don't have to match the factory. The idea is that some other poor bastard can look at my work, look at a manual, and figure it out.
    May 2012
    VA
    This is the closest I have found: http://www.prowireusa.com/Mil-Spec-Wire/departments/74/
    Not the exact same color locations, but the same colors (i.e. blue/red) can be used on a specific wire. The original metric wire has a specific diameter (which is in mm) but I have yet to find an instance where that dimension is critical. Good luck!
    Stan
    AH# 13238
    Oct 2010
    Manley Hot Springs Alaska
    Napa
    My local Napa has Arctic grade wire,flexable at any temp.and in many colors and sizes.IMO much better than the brittle stock wire.
    Pismo Beach, CA
    I just spoke with John at Benchmark Works (yes, they are open on Mondays). They do not have, nor do they know of, a source for new, bulk, BMW OEM color-coded wire.
    Rusty Gill (MAXBMW (NH store) guru) would be my next option, but they are closed on Mondays.
    Lew Morris
    1963 Dnepr
    Jun 2007
    Portsmouth, NH
    Try this place: Rhode Island Wiring Service
    http://www.riwire.com/
    Albuquerque, NM
    I know it's an "out there" suggestion, but just remember that ALL German vehicles use the same wire color coding, as it's the Bosch/DIN standard. Therefore a fairly high end restorer of Mercedes may have a wire source. Point being, just checking motorcycle sources is a bit limiting.
    Kent Christensen
    21482
    Aspiring Profligate Jeff488's Avatar
    Apr 2007
    Nacogdoches, TX
    Given what lKchris said, perhaps an auto scrap yard with German vehicles in it would be worth a visit.
    '08 BMW R1200RT
    '75 Red R75/6
    '08 Suzuki DL650 "Screaming Yellow Zonker"
    Looking for Ed Sanders' Truck Stop.
