Results 1 to 10 of 10
Thread: Removing the Cockpit Bar ('06 GS)
    Registered User bobframe's Avatar
    Jan 2013
    Northeast GA
    I plan to install a BMW GPS Mounting Bracket (Part # 71607713903) that I bought at a dealer today on my 2006 R1200GS. I thought I'd ask the service manager for any Tips/Tricks (there's always a "trick") before I left and he grimaced when I told him what I wanted to do. He said "Its a difficult job. BMW has painted the T-25 torx bolts that have to replaced (so the Torx fitting is somewhat filled with paint and the edges are completely "painted in") and if that's not enough, the windshield and the speedo/instrument cluster needs to be removed."
    He spent a few minutes with me pointing out what needed to be done and it does look like a nasty job...fraught with the risk of totally hosing up the torx bolts that need to come out.
    Has anyone done this and have any words of wisdom for me?
    Many thanks,
    Bob
    P.S. I looked at the similar Touratech product (http://www.touratech-usa.com/Store/1...38ea50b1fc97ec) and their installation instructions warn of the same install challenges.
    We don't take a trip...the trip takes us.
    2006 BMW R1200GS
    2008 BMW R1200RT
    I've not removed the cockpit bar. I have removed the windshield and instrument cluster. Both are very easy and quick jobs on the GS.
    TravelsWithBarley.com
    Jan 2009
    Craftsbury, Vermont
    Definitely remove the cluster. Put some oomph behind your torx bit and be sure it's square. Your dealer is right - it strips easily and is a bear to get out once that happens. If you blow your one chance, a drill bit in a flexible shaft attached to a Dremel will give you enough of a dimple to get a busted screw extractor in there. You can probably guess from my description that the first attempt did not go flawlessly for me.
    '12 R1200GSA for solo rides
    '10 R1200GSA with Hannigan dual sport sidecar for rides with Tulliver
    Jan 2013
    Northeast GA
    Quote Originally Posted by glenfiddich View Post
    Since it sounds like you've done this...did you attempt to remove any of the paint from around the screw before trying to loosen it?
    2006 BMW R1200GS
    2008 BMW R1200RT
    Jan 2009
    Craftsbury, Vermont
    I did not, Bob. In my vanity of refusing to admit my eyesight is fading I never even noticed. On the other side firm pressure at a right angle worked just fine.
    Pete
    Jan 2013
    Northeast GA
    Pete
    I'm encouraged. Think I may try to cut the "paint seal" between the screws and the mounting bar. I finally broke down and bought a set of Torx sockets yesterday...that should be a major improvement over the Mickey Mouse Torx wrenches in the OEM tool kit. Which is another project soon to be tackled....i.e., creating a really usable and packable tool kit.
    2006 BMW R1200GS
    2008 BMW R1200RT
    Jan 2013
    Northeast GA
    Eureka!
    Just finished installing the bracket in about an hour start to finish. It really wasn't bad after all. Windshield came off in minutes and the speedo cluster was simple as well. The painted in mounting bolts broke loose much easier than I feared. I think the Torx sockets I picked up yesterday made all the difference...applied firm pressure into the bolts and they broke loose. The new mounting bar installed perfectly and I also added a quick release, 4 bolt mounting bracket into which my Garmin Zumo 550 will bolt.
    Now if I could just find that damned accessory port. Wonder if the PO did away with it. I've looked everywhere (I think).IMG_0491.jpg
    2006 BMW R1200GS
    2008 BMW R1200RT
    Jan 2013
    Northeast GA
    Quote Originally Posted by bobframe View Post
    Hooray!!!! I found the plug. Next step will be to splice the wiring from my Zumo 550 into the plug I bought at dealer yesterday. Any issues with this?
    Thanks again for the help,
    Bob
    2006 BMW R1200GS
    2008 BMW R1200RT
    Pins 1 and 3 are power, pin 2 (middle) is unused. Be very, very sure that your GPS likes 12V and not 5V like some. I had to wire in a 12V to USB (5V) converter to power my non-garmin GPS. I don't know what the Zumo needs.
    Jan 2013
    Northeast GA
    My Zumo 550 has been living on my Honda ST1300 for two years...I believe its been eating a steady diet of 12V. But I appreciate the heads up.
    2006 BMW R1200GS
    2008 BMW R1200RT
