Results 1 to 15 of 27
Thread: Oil usage thread 2011 R1200Rt
    Registered User lvermiere's Avatar
    Jan 2004
    Grand Forks B.C.
    I know.yes I know the feeback that has been given on the site about oil usage, new bikes and time.. ... whatever one more time fduring these non riding says...
    History-My 99 RT using conventional m/c oil after 27,000 miles went to synth. after lets just say i kept it at high speed for a lot of hours. It quit using oil then and then I went synth. The engine noticeably loosened up and was deemed broken in. It now has 270,000km on it and it is in mid life.
    Situation: 2011 R1200Rt 10k miles using synth since 2,500 miles. Uses 1 qt/2,000 miles. Normal as per BMW. Way More oil usage than I would like.
    At this mileage I could 1. use conventional m/c oil and run it until oil use drops i.e another 10 k miles.
    2. Run it hard with synth in it and add oil, like a lot. Forever?
    The question that has been dscussed in other threads - is the bike broken in/engine sealed at full compression at 10 k miles?. Can I put nonsynth in and run it ( high speed/rpm) until the rings finally seat like they diid for my 99 or am I stuck with running an oil user/suck?
    I'm thinking of going with a new engine ring seating regime. By me to ebb the oil use= Plan- run Non synth run for 10k to seat the rings, and I should be good to go???
    What is your $.50 on this? This is way more than .02 Cents for most of the feedback on her
    Last edited by deilenberger; 01-30-2013 at 03:37 AM. Reason: added year/model to title
    Spring Lake NJ, USA
    LVERMIERE,
    Please read: http://forums.bmwmoa.org/showthread.php?46055 - I've added that info to the thread title. It has some significance since there are two different engines covered under the "hexhead/Camhead" forum, and that might just make a difference.
    PS: - real name?
    May 2006
    Northern New Jersey
    If it were me, I'd go back to real oil for another 10K then re-evaluate things. And not worry about anything until then. I think you went synthetic way too soon. There's conflicting comments from BMW dealers , different ones say switch after 600, 6,000 or 12,000 miles. No wonder we're all confused, they are too!
    Sep 2009
    Chestnut Hill, MA
    2008 R1200RT - 30,600 miles
    FWIW, my RT still uses a few ounces of conventional i.e. non-synthetic oil every 5000 miles.
    John Gamel
    2015 Ebony Metallic R1200RT
    BMW CCA 2006 - Present; BMW MOA 2009-Present
    Walt Kelly: "We have met the enemy, and he is us."
    Jan 2004
    Grand Forks B.C.
    Smile
    LVERMIERE,
    PS: - real name?
    Thanks Don.
    I deliberately left out the year of bike in the title as both the hex and cam heads have been experiencing the same oil useage. I figured I would get a greater amount of feedback with the hex's included.
    Yes, my real name, put on the board the same way as you've done yours
    FWIW, my 05 RT used non-synthetic oil until almost 30K miles. Then it stopped using any, so I switched to synthetic. Never needed to add oil again between oil changes.
    YMMV
    Registered User liv2ride's Avatar
    May 2012
    Honolulu, HI
    2012 R1200RT with 4k miles
    My bike is thirsty too. I researched enough prior to buying the bike to not make a fuss. Yes, I used about the same as you...1Qt from the 635 mile service to 2300 miles. At 4k I see the consumption appears to be slowing...already.
    My dealer indicated BMW recommended full synthetic (15w-50) at the first change; I didn't want to argue to ensure I was supported in the event there was a warranty claim. I did question the mechanic, of whom I trust, and he indicated he could use dino if that is really what I wanted. I chose to go with BMW's "latest" guidance on oil to be used.
    Yes, I get that there are several schools of thought regarding an engine break-in re: mileage, oil, riding style, temperature cycling, etc. This is the first time that I gave in to my traditional way of thinking that you should run dino oil up to at least the first 3k.
    I can say that I did break the bike in per the BMW manual, which I have done with every other bike. I have and continue to use engine breaking extensively and revved to the identified limit often during break in to help bed the rings.
    I am optimistic this condition is not chronic and even with synthetic it will resolve itself with mileage.
    Scot
    Apr 2012
    Maryland
    15,000 miles on my '12 GS/A, and I'm still using nearly a quart every thousand miles. Bike was broken in properly. I have added more oil to my BMW in 15,000 miles and 9 months than I've added to my Harleys in nearly 150,000 miles and 8 years. It's ridiculous that I can't travel on my bike without carrying spare oil.
    It's my only complaint about the bike, but it's a big one.
    na1g
    May 2011
    Greater Bahstin, Massachusetts
    "It's my only complaint with the bike, but it's a big one."
    Ditto. My 2011 RT has about 11K on it and continues to use oil - about a quart in a thousand, all petro - although the rate seems to be very slowly dropping. That may be within spec for BMW but is not acceptable to me. Checking the oil level at every fill-up is routine for me anyway, but adding oil every second fill-up just to keep the level up should not be. I put over 50K on a Honda ST1300 and it used maybe 4 ounces of oil total in that time.
    Let's hope they do better with the water-cooled boxer.
    pete
    "Be yourself. Everybody else is already taken." - Oscar Wilde
    May 2006
    Northern New Jersey
    Quote Originally Posted by 05Train View Post
    In the greater scheme of things, I'd say using some oil is a minor thing compared to something like a FD failure. THAT I would consider a big complaint...
    Mar 2008
    Camas Valley Oregon
    Bought my first oilhead a 2004 RT and rode it like I stole it from day one. That red line on the tach is there for a reason but anything below that was fair game. That bike never used a drop of oil and all it had put in it was 20/50 dino. Now I've got a 2006 RT bought used at 8,000 miles. I ran dino for the first oil change and it didn't use any so changed to synthetic (Mobil 1 M/C) and it still doesn't use any oil. YMMV but knowing the prior owner of my 06 I'm pretty sure he didn't baby it either when new.
    Marty - in the western Oregon mountains.'06RT, (gone '04RT, '86 Venture Royal, '81 Yamaha Virago920, '82Suzuki GS1100GK, '76 Suzuki GT750, Triumph 750 Bonneville, BSA Road Rocket 650, 61" Harley knucklehead)
    Apr 2012
    Maryland
    Quote Originally Posted by ClassicVW View Post
    That's great. Doesn't change the fact that it's ridiculous that a modern motorcycle in 2013 uses this much oil.
    Registered User apexal's Avatar
    Nov 2011
    Dover, NH
    I agree. My 2011 GS used a quart every 2000 miles until I got about 6000 miles on it. It pretty much stopped using oil after that but I don't dare go too far without carring spare oil with me just in case. My local dealer said the bike needs 12,000 for break-in then I can switch to synthetic and that's my plan.
    My 2012 RT has 3000 miles on it and hasn't used a drop. Like the GS I'll put on 12,ooo miles then switch to synthetic.
    In the last 10 years I've had 3 new Ducatis, 2 new Moto Guzzis and 1 new Triumph, and none used oil. But if using oil is the price to pay for riding the BMWs then I'll gladly pay.
    Dover, NH
    2014 BMW R1200GS Racing Red
    1973 BMW R75/5
    Mar 2004
    Northern WV
    Oil usage typically stops somewhere between 8-20K, so hopefully yours will end soon. I'll just add two things;
    1)Hopefully you have been frequently running the engine a bit hard, as in 80%+ throttle acceleration up a long grade in 4th gear?
    2)Also be sure to *only* check the level after the bike is fully warmed up then shut off and left on the side stand, for at least 30 minutes (I usually just leave it on the side stand overnight) then lift it on the center stand and check the level. Doing it any other way will often give a false low oil level reading, so "topping up" to normal is actually over filling. Every time this occurs the engine simply blows the overage out the breather. The owner is depressed every time he adds oil again. When *correctly* checking some say if you can see any oil in the glass at all don't add any. I'll say if it's 1/4 way up from the bottom of the circle (or higher) don't add any.
    14 R1200GSA, 93 R100R, 15 FJ-09, 15 Road King, 07 Moto Guzzi Griso No car is as fun to drive as any motorcycle is to ride.
    Apr 2012
    Maryland
    Quote Originally Posted by milo View Post
    Oil's at the bottom of the sight glass with the "oil check" showing in the display. Your guidance doesn't match what the manual states. I check it per the manual.
    It's BS that a $20,000+ bike goes through this much oil.
