Results 1 to 13 of 13
Thread: The Cat's Meow For Splines, I wish
    Just opened my 2002 1150 at 62k miles for transmission input shaft inspection/lube. Splines perfect fortunately. Looking at the shaft (instead of a picture) for the first time I saw one of the reasons for failure. The shaft is TINY. Read here about an improved clutch disk with a longer hub which is certainly an improvement if the shaft hasn't trashed yet.
    But if the shaft is stripped or on it's way I think I've seen $1G for a new shaft plus a transmission tear-down.
    Since someone has the capacity to install a longer hub in a clutch disk, then they could just as easily install a BIGGER hub. Larger OD. (Stay with me) Now add a simple machined collar over the damaged shaft, old spline size for the ID, new, bigger splines for the OD. The stripped ones appear to have enough spline left to hold the repair collar, just in the wrong place to engage with the clutch. A snug fit and Stud and bearing Loc-Tite or Caterpiller branded epoxy would easily hold it on. The only force applied longitudinal is generated by the riders lift hand on the clutch lever. Cheap, easy, straight-forward manufacturing, no transmission tear-down.
    The spline size is adequate if the splines are kept lubed with the right grease.
    My guess is that a bigger spline would last longer but still fail without proper lube.
    My 2 cents.
    Mike Marr
    Registered User PAS's Avatar
    Jun 2011
    N.E. Ohio
    Why dont cars and trucks require spline lubes? Winter boredom question.
    Florida & Massachusetts
    Good question, and I'd add, a second, why don't cars and trucks required yearly valve adjustments?
    2-up and havin' fun sugarhillctd's Avatar
    Oct 2007
    Just above the Notch, NH
    That's easy....
    Hydraulic lifters
    John & Cathy
    '92 K100RS (gone- '04 R1100S Boxer Cup)
    SS1000, BBG
    Quote Originally Posted by MotorradMike View Post
    My 2 cents.
    The idea was about salvaging an expensive damaged shaft. The larger spline would just be a added bonus. As pointed out by others, cars and trucks don't need a tear-down periodically for a spline lube. Why should these motorcycles?
    IBA #44567 Ken F's Avatar
    Sep 2009
    SW, MO
    I would say that there is much more movement of the shaft on the splines due to a short driveshaft, and long suspension travel.
    Ken
    -Albert Eienstein
    Sep 2004
    minnetonka mn
    Quote Originally Posted by GKman View Post
    Epoxy is strong - but not that strong, especially with at higher temperatures.
    Also - the spline system would maybe be be ~25% stronger if there was a full axial engagement, but I don't think engagement is the life issue here. Poor alignment and fretting corrosion is what's wrecking these parts.
    RK Ryder
    London, Ontario
    I sent my K bike rear drive to Bruno for a rebuild. It came back with a much longer set of splines to lubricate. A few years late, took my K to a dealership for a spline clutch and clutch repair. After paying the bill the service manager said that someone had tampered with my rear drive and tooled it back to specs. Haven't been back there since.
    Paul
    Knights of the Roundel #333
    Ken
    Wrong shaft Ken. Talking about the clutch end.
    Quote Originally Posted by nrpetersen View Post
    I calculated at least 1.75 square inches of surface area just on the faces of 17 splines X 3,000 psi epoxy = 5,250 lb. If I subtract 25% for missing/ damaged splines there's still two tons resisting being pulled off (a direction there is very little force applied). Green Loctite is rated for 450F. Do you expect to see that in your clutch housing? I guess John Force might, but I'm not recommending a fix for one of his funny cars.
    JohnWC
    Akron, Ohio
    I like the idea of a replacement collar. It could be sold as a kit: collar, new disc, adhesive, pins,etc. But am I mistaken that the most force on this shaft is not the back and forth drag of the disc, but the rolling force of the disc on the splines. And that is probably considerable. To counter that, couldn't the collar come with either several set screws at different points, or, if the shaft is not hardened, pilot holes in the collar to allow the installer to drill through the shaft and install roll pins to prevent the collar turning on the old splines? The collar could be hardened and would probably outlast the original shaft splines, which, from BMW's point of view, need to be pampered regularly. I notice that in the new R engine, BMW finally gave up on this system and went with a wet disc clutch. Good.
    jconway607,
    Thanks for your interest and input. The details you mentioned are ideas that need to be explored and tested to make a quality product. I have no interest or need to develop the idea. I entered it into this public domain in hopes that someone would take an interest and develop and market it.
