Results 1 to 5 of 5
Thread: 2008 GSA Footpegs
    Watch This!!! junkjohn's Avatar
    Feb 2010
    Cape Cod, MA
    2008 GSA Footpegs
    After only 19,500 miles I have noticed that my boots are starting to saw threw at the arches, from the saw blade type footpegs on my GSA. Is there a remedy other than my favorite gray tape? I have been wearing Redwings with Vibram soles.
    John Simonds
    2008 R 1200 GSA
    1975 Norton Commando 850 Roadster Mk 3
    If it ain"t broke... fix it till it is.
    Albuquerque, NM
    R1200R footpegs.
    It used to work that way, anyway.
    Or ... item #2 from your dealer
    Kent Christensen
    21482
    Feb 2010
    Cape Cod, MA
    Thanks, that looks like the solution.
    John Simonds
    2008 R 1200 GSA
    Registered User Woodbutcher's Avatar
    May 2010
    Austin, TX
    Just part #2 won't work for a GSA. Works on the GS foot pegs, but the GSA ones are wider and the rubber insert won't snap in. Or I'm pretty sure on that. You could order GS foot pegs with inserts though. Or grind down the top of the teeth on the GSA pegs some.
    But 20k miles out of riding boots sounds decent to me. Plus, if they are steel shank then it won't go all the way through anyway.
    Rusty
    Austin, TX
    Two Wheeled Texans
    2009 R1200GSA
    Feb 2010
    Cape Cod, MA
    After looking at that illustration, I think I will make my own rubbers out of an old hockey puck. Thank you for the heads up.
    John Simonds
    2008 R 1200 GSA
